Is there such a thing as a virtual device that will read temperature, relative humidity and air pressure from a sensor and use that to calculate the absolute humidity?
Thanks in advance
Thanks in advance
Not that I'm aware of, but if you have a formula for calculating that value using these inputs, you can write a rule that does so and stores the value in whatever you want, including a hub variable you could use in apps or display on Dashboard.
Not a virtual device but this comes from my Ecowitt bridge.
There is a calculation mentioned in this post but I have no idea how to implement it in webcore.
I have several webcore variables for all the required information, temperature etc. If anyone can help with putting this all together that would be great.
