I was looking for good quality switches, that would handle 16A load, 10A load capable switches are easier to find, but it is not enough for me. I had electrical installation designed to handle 16A, so I did not want to limit myself to 10A, by too "weak" switches.
Let's go straight to the point, to the results of my tests/findings. Finally, I found two interesting switches:
#1: Aubess, have better coverage and range, initially it covered 4x other nearby devices, most critical for me. They (other devices, not switches) had issues with communicating directly with hub. After several hours, Aubess connected to itself even more devices than initially, up to 9x.
#2: Avatto, initially it connected more devices, (6x), but only 2x nearby, (most critical for me), next 2x was not connected, it connected some devices far-away, but not all nearby.
Both devices was connected in "quick and dirty test station", in same place, there could be some minor difference in placement (+- few centimeters), that should not affect results.
Both devices according to seller's declarations should handle 16A load. I did personally load test, by connecting to them 400W hair dryer and 1800W infrared heater (in sumary 2200W, approx 10A), and keep load by 30 minutes. After that time, cables got slightly warm (35 deg C), devices got 30-35 deg C (Aubess got hotter, 35 avg, Avatto 30 avg), both devices had approx 42 deg C on connectors.
Both are easy to pair with hubitat, both have "on" state indicator, both have button used to pair and change state manually, Avatto have "beeper", that is giving sound. Both are in general fine.
#1: https://www.aliexpress.com/item/1005003607187952.html
- manufacturer: _TZ3000_46t1rvdu
- model: TS0001
#2: https://www.aliexpress.com/item/1005005558002990.html
- manufacturer: _TZ3000_4rbqgcuv
- model: TS0001
both are working on driver:
Zemismart ZigBee Wall Switch Multi-Gang
#3a: https://www.aliexpress.com/item/1005004729107536.html
- manufacturer: _TZ3000_xkap8wtb
- model: TS0001
#3b: https://www.aliexpress.com/item/1005005459084252.html
- manufacturer: _TZ3000_kqvb5akv
- model: TS0001
Both should work on driver: Tuya Zigbee Metering Plug (tested only OEM variant, current version of driver, status per day 18.07.2023), after manual selection (correction) of device driver, and after initializing device. Observed temperatures (after 30 minutes of 2300W load) are more or less comparable to previously tested devices (+- 42 deg on connectors). Power monitoring is working. This so far first (and probably only one) mini smart-switch with power monitoring. Same device is sold by few other sellers on ali-express. OEM Aubess / "No-name" have very good coverage too (looks like almost identical or slightly better than non-metering Aubess). Possibly both devices are from same factory, they look in extremely similar way, only printed information are different.
And... looks like, that this is OEM version of that Aubess switch, even size of plastic is matching to Aubess with power monitoring, photo here:
link to Aubess with monitoring specs bellow:
Example of (working) power monitoring bellow:
Summary:
I'm rating them,
4/5 for Avatto, (due to worse and less consistent mesh coverage),
5/5 for Aubess,
5/5 for Aubess with power monitoring (or it's OEM version).
Note: identification data are given, at the moment when I tested it. Further versions of devices could have it different, and behaves in different way.
I noticed even presence of 30A switch with power metering:
https://www.aliexpress.com/item/1005005177454284.html
or without(?) power metering:
https://www.aliexpress.com/item/1005005444910065.html
But neither I need 30A, nor it will fit my installation boxes, so I'm not planning to test them, and I saw (in other link) some negative reviews about smaller one (black, with metering) 30A switch.
Other (multiple channels, certified to handle less than 16A) bellow:
#4: https://www.aliexpress.com/item/1005005558002990.html
- manufacturer: __TZ3000_mtnpt6ws|
- model: TS0002
working on driver: Zemismart ZigBee Wall Switch Multi-Gang.
Designed to handle 5A per channel.
