Hi,
Quite often I clone a rule and paused it as a method of version control of my automation rule.
It would be nice if there is a way to hide the list of paused rules; thus I can see the cleaner UI
Hi,
You could disable the rule instead using the X in the top right of the apps tab. Check the rule you want to disable then click the X again to hide the column that shows up. It doesn't hide the rule but it does make it easier to look through at the rules that are disabled.
Thanks for your reply, yes I'm aware that feature already.
Ideally to have the ability to hide all paused rules to declutter the UI.
