Excellent suggestions. Thanks for joining in.
Much better
I haven't contributed anything to the community in a LONG time so I figured...why not?
Plus I have everything in HA so I could be a good example of what would happen to most users if they integrate a ton of devices from HA into HE.
I was hoping to attract the advanced users/developers with a lot of HA experience to this effort. Much appreciated!
Added version number
Another thing that would be helpful for updates would be adding an importUrl to the definition so each update would be "one click" for the user.
definition (name: "HomeAssistant Hub Parent", namespace: "ymerj", author: "Yves Mercier" ,importUrl: "https://raw.githubusercontent.com/ymerj/HE-HA-control/main/HA%20parent.groovy") {
Done. Thank you.
@ymerj - I just submitted a pull request to which adds temperature and humidity sensors.
Arghhhh!!!!!! you people are going to force me to install HA now.. I have been resisting the siren song of yaml configs.
It's annoying that installation on "generic Linux" is no longer supported. Have an oDroid N2 and do not wish to re-burn the emmc. Oh well - have to see if I have YARPi (Yet Another Raspberry Pi) around.
On the plus side I do have a left over Nortek stick from a cloud/network only C-4.
Yup. Agreed. These days they call it "bare-metal Linux", and I was unhappy to see that it is not only unsupported, but ridiculously onerous to put together on one's own.
I'm running it off Virtual Box right now. Soooo easy to setup and then you get HASS.IO so you have the Supervisor and the Add-on store. Much more goodies to bring into HE
Merge done... I wonder, do I need to inform you or do you get noticed anyway?
Thank you!
I receive an email directly via GitHub when one of my pull requests is approved, denied, or a comment is made.
Looking great. Incredible progress in a short period of time. I'm testing on HASS.IO at the moment and it's looking great. No more trouble with devices coming in from anything, not just the Zigbee radio.
Note: Open and Closed is reversed for the contact sensors.
Will test a temp/humidity sensor now.
Excellent! Could you please add barometric pressure too.
sensor.lumi_lumi_weather_7add3d03_pressure
From HomeKit Controller
Direct joined
No can do, as Hubitat does not have a “Generic Component Pressure” driver type in the firmware. Right now, we’re using only the built-in child device drivers.
I submitted a pull request to reverse this logic.
Ah, I understand now. Well I have a shock/vibration/angle sensor available for testing and we have Generic Component Acceleration Sensor.
@mike.maxwell
We could use in an upcoming build:
Generic Component Illuminance Sensor
Generic Component Pressure Sensor
Please and thank you
I think all the open/close logic should reverse, shouldn't it? Not just door ?
I can submit pull requests if someone can show me how to do it without screwing things up.
I merged, not sure what to do after that.
Seemed easy enough. Submitted reverse to garage door, opening, and window.
I updated to the new version last night with temp and humidity. I now have about 150 sensors reporting and all still seem fine. HE logs are noisy of course.
The log has been clear of errors except for one. This is a battery state sensor (not a level sensor). It reports "charging" or "discharging" etc.
Edit:
Looking at their documentation, this sensor should not have been added to the battery device class. It probably should have been a generic one. The sensor generating the error is created by the official android HA app so it looks like they are breaking their own rules.
