433 MHz Pico remotes interfere with the Bond/Broadlink hubs controlling a 433 MHz ceiling fan
I have a 433 MHz Harbor Breeze Ceiling Fan/Light that I can control with the Bond bridge or a Broadlink RM4 Pro. Control works perfectly when I do it directly using the Hubitat device page. So I setup a Lutron Pico to control the fan, only to have it work very sporadically - requiring multiple button presses, and even then the device wouldn’t respond about 50% of the time.
Based on logs and LEDs flashing, I know that both the button controller app was working and the bridge/hub was sending a command to the ceiling fan - but the fan wouldn’t respond. I just figured out why this evening. ClearConnect transmissions are interfering with the fan receiving RF commands from the Bond bridge or Broadlink hub.
Control is perfect when done directly from the Hubitat device page, or if I substitute the Pico with a zigbee or zwave remote. Finally using any Pico while sending a command from the device page results in about 30-40% of the commands failing.
First time I’ve encountered this interference with Picos.
You must have missed my post from 2020. :grin:
The Pico is still sending messages when the Bond starts. It drove me crazy!
Someone else posted similar problem in the last couple of months.
Even more embarrassing - I participated in that thread :face_with_open_eyes_and_hand_over_mouth:
I just ordered a few Zen37 z-wave remotes to deal with this situation.
