I need help. I'm trying to add a third Hue Bridge (v. 2.0). I figured to start from scratch, and so removed all instances of the Hue Integration App. The first two bridges installed without issue (including the actual new "third" one). The final bridge (actually was in use prior without issue) is discovered, and when I click the button on the bridge I get a "success" message. However, when I click through to select lights and groups, I keep getting an error message.
My log shows the following...
I've tried this several times. Is there a restriction to a third bridge?
Thanks!
