I have a dimmer and and a remote dimmer switch that I currently have setup as a 3-way dimmer in SmartThings. I setup the primary dimmer as a Generic Z-wave Dimmer and it works fine. I can't figure out however how to set up the secondary switch as a Linked Dimmer device. Is there any documentation on this. Clicking on "Add Parent Dev" does nothing.
What is make and model for these devices?
I thought you already figured this out using a Minimote?
Yes, I did figure out how to do it with a minimote. I forgot I had posted this in 2 different places.
It should still be addressed within the Hubitat environment though because not everyone has a minimote and they're not being made anymore.
How does it work in ST to setup 3-way?
