220V light switches supported by Hubitat?
Hi, I was checking the list of supported devices in the Hubitat documentation site and I found that most of the ones listed are 120V only with no support for 220V, other than the Fibaro one which is not really what I am looking for. I would like a full light switch instead of the type where you hide something behind the switch. I'm fine with simple on/off types with either Zigbee or Z-Wave support.
Are there any other choices for those of us who can't use 120V wall switches? Thank you.
Just buy mains switches/devices of the voltage of your house.
HE doesn't care what the voltage they are it just controls them via zwave / zigbee etc.
If they are not listed on the compatible devices list, just do a search on here. You will probably find that someone has already provided code to make them compatible.
or better yet, if said device works perfectly with a built in driver, post up the fingerprint, then a new owner of said device wouldn't have to go hunting...
