I have created a scheduled rule using the sunrise/sunset handler.
I keep getting this error when it runs. I have tried deleting and recreating it.
(http://192.168.1.106/installedapp/configure/210)java.lang.NullPointerException: Cannot get property 'i' on null object (sunrisesetHandler)
Update: bug found and fixed. Will be in the next release. In the meantime, you could use a simple trigger since you have this run every day of the week.
I was getting this exact same error in my rules also. I reported it to support and they are still looking at it but if this is a real bug fix them Iām glad to see it fixed.
Thanks for the reply. Later this afternoon, I will recreate the setup on my other post and add some screen shots. I'm fairly certain there is a bug there
Oh, there definitely was a bug there -- as in it didn't work for sunset/sunrise at all. It would work for times that are offset from sunset/sunrise. This bug has been found and fixed, and will be in the next release.
