I want to control a ventilation fan that has two speeds. It is a 1/3 HP, 120v single phase motor with two hot terminals, one for moderate RPMs and one for max RPMs. The motor is rated at about 5.5 amps at full speed. The mfgr offers a simple toggle switch that lets you put hot on the center terminal and send it out one of two connections depending of if you flip the toggle up or down. I'd like to emulate that function in a Z-Wave smart switch.
I think the Zooz ZEN16 multirelay box looks like the right idea, or maybe the ZEN17, not sure. Any thoughts?
Fan: Dayton 4TM81A (1/3 HP)(1750/1140 RPM)(5.5/3.6 amps)
Edit: Totally looks like the ZEN17 is the way to go:
WHOLE-HOUSE FAN: 120 V to R1 C, neutral to neutral, fan low speed
to R1 NO; fan high speed to R2 NO.
