Can you try this driver?
Before assigning it to your device, you will need to manually edit line #46 - replace "_TYZB01_v8gtiaed" with your manufacturer ID _TZ3000_ha4ejozn. Then save the modified driver, assign it to your device and press Configure button on the device web page.
If it works, you can ask in the linked driver thread that your device fingerprint is included in the next driver version.
If this driver doesn't work - please post some debug log transactions, when you press the device physical buttons.
