I recently purchased a two button Pico remote, to control two lights in my Tiki bar.
Both the top and bottom buttons (Button 1 and Button 5...) are used, each to toggle a different light.
I was going to add another light, and make use of the dbl tap, but this is not an option for this remote.
Any ideas?
Can I fool it into thinking it is a 5 button remote? Or would that make any difference?
All of my other 5 button pico remotes have dbl push.
I am using the Fast Pico Driver; I was not aware that there was an enhanced pico driver.
How is it different, and how can I find it?
They do not. Maybe we are talking about the same thing different ways, but Pico are Push, Held, and Release as to what options you have.
If you are not using the Enhanced driver I doubt that your other 5 button have anything but push.
You have to select Fast Pico or the Enhanced Pico when you do the Lutron Integration process in Hubitat. You cannot just change the driver after the fact. You need to recreate these devices, change the Lutron Integration app (in Hubitat) to match the desired driver. It will then create new devices with the Enhanced driver.
I guess in theory, if you were willing to put with the delay, I suppose you might be able to use rule machine + Fast Pico to count clicks for 5 seconds before sending a command and then firing off a different command based on how many times the button was pressed within 5 seconds of the first click.
Skeptical it would be worth the effort but now Iām kind of curious to try it. Haha
