Finally getting around to replacing my RGBWs with the ZEN56 (yah, they got dusty on the project table and just now getting back to them.) The built-in driver appears to create a child device (just one for white) with Parameter 16: 1 – Channel Endpoints Hidden (default) and theoretically I gather does 4 total if the parameter is set to 0.
The Parent driver handles RGB and W using a mix of those channels, as well as controlling the built in animations. And seems to work just fine.
Even better, white is created as a child device allowing for an easy-to-control regular switch and actually appears to control the W channel of my strips as expected.
HOWEVER, I can’t seem to get the On/Off to actually operate unless the parent is on. But that leaves me theoretically having to set level down to 0 or 1? to use the W channel.
Do I have some odd install artifact going on here (all 3 devices are set this way from when I was first debugging and reporting some issues back in the beta) or is this by design (either Zooz or Hubitat intended??) If so, am I being stupid as to how to use this properly? Is it a bug in our driver, or a reason to reach out to Zooz and see about a firmware change?
Thanks. Maybe I’m missing the magic, but this is annoying… (@bcopeland this relates to the oddity of child on/off behaviors I reported as a quirk on the now-fixed parsing issue post in beta forum - I’m able to dig into this more if you need anything from me and it’s not as intended)
Update since yesterday: This behaves the same for a new install of a ZEN56 as well.
