[2.4.1.157] ZWJS Zooz RGBW ZEN31 Warnings and state not updating
Another RGB'ish warning issue:
Screenshot 2025-04-13 at 6.46.54 PM
dev:2556 2025-04-13 06:38:16.973 PM warn ignore: MeterReport(meterType: 1, precision: 2, scale: 0, size: 1, meterValue: [66], rateType: 1, deltaTime: 0, previousMeterValue: []) (1)
dev:2556 2025-04-13 06:38:16.867 PM warn ignore: MeterReport(meterType: 1, precision: 0, scale: 2, size: 1, meterValue: [0], rateType: 1, deltaTime: 0, previousMeterValue: []) (1)
dev:2556 2025-04-13 05:38:26.382 PM warn ignore: MeterReport(meterType: 1, precision: 2, scale: 0, size: 1, meterValue: [66], rateType: 1, deltaTime: 0, previousMeterValue: []) (1)
dev:2556 2025-04-13 05:38:26.286 PM warn ignore: MeterReport(meterType: 1, precision: 0, scale: 2, size: 1, meterValue: [0], rateType: 1, deltaTime: 0, previousMeterValue: []) (1)
dev:2556 2025-04-13 04:38:36.203 PM warn ignore: MeterReport(meterType: 1, precision: 2, scale: 0, size: 1, meterValue: [66], rateType: 1, deltaTime: 0, previousMeterValue: []) (1)
dev:2556 2025-04-13 04:38:36.114 PM warn ignore: MeterReport(meterType: 1, precision: 0, scale: 2, size: 1, meterValue: [0], rateType: 1, deltaTime: 0, previousMeterValue: []) (1)
dev:2556 2025-04-13 03:38:46.306 PM warn ignore: MeterReport(meterType: 1, precision: 2, scale: 0, size: 1, meterValue: [66], rateType: 1, deltaTime: 0, previousMeterValue: []) (1)
dev:2556 2025-04-13 03:38:46.203 PM warn ignore: MeterReport(meterType: 1, precision: 0, scale: 2, size: 1, meterValue: [0], rateType: 1, deltaTime: 0, previousMeterValue: []) (1)
dev:2556 2025-04-13 02:38:55.461 PM warn ignore: MeterReport(meterType: 1, precision: 2, scale: 0, size: 1, meterValue: [66], rateType: 1, deltaTime: 0, previousMeterValue: []) (1)
dev:2556 2025-04-13 02:38:55.367 PM warn ignore: MeterReport(meterType: 1, precision: 0, scale: 2, size: 1, meterValue: [0], rateType: 1, deltaTime: 0, previousMeterValue: []) (1)
dev:2556 2025-04-13 01:39:05.542 PM warn ignore: SensorMultilevelReport(precision:0, scale:0, sensorType:15, sensorValue:[], size:0, preScaledSensorValue:0) (9)
dev:2556 2025-04-13 01:39:05.443 PM warn ignore: SensorMultilevelReport(precision:0, scale:0, sensorType:15, sensorValue:[], size:0, preScaledSensorValue:0) (8)
dev:2556 2025-04-13 01:39:05.343 PM warn ignore: SensorMultilevelReport(precision:0, scale:0, sensorType:15, sensorValue:[], size:0, preScaledSensorValue:0) (7)
dev:2556 2025-04-13 01:39:05.252 PM warn ignore: SensorMultilevelReport(precision:0, scale:0, sensorType:15, sensorValue:[], size:0, preScaledSensorValue:0) (6)
dev:2556 2025-04-13 01:26:40.568 PM warn ignore: MeterReport(meterType: 1, precision: 2, scale: 0, size: 1, meterValue: [66], rateType: 1, deltaTime: 0, previousMeterValue: []) (1)
Again, an internal driver and again, "just a warning" BUT this time, it appears to affect the Current States because they are inaccurate. Changes in the RGB child app do not update Current States.
The correct Current States would be "ON" and a color of "Orange", for example.
Screenshot 2025-04-13 at 6.49.19 PM
I can't be sure, but I think the current states reflect the states from just before upgrading to ZWJS a week or two ago.
@bcopeland
I think the current states are not updating due to the other error you posted: [2.4.1.157] ZWJS parse warning
These Meter reports I think are always ignored by the system driver. I forget what the SensorMultilevel does for this devices but I suspect is one of the other options sensor input options that pretty much no one uses.
My custom driver supports some of it, but it wont help with the parse errors reported on the other post, thats internal functions to Hubitat that need to be fixed.
Thanks, :slight_smile:
but I point out that it's two different drivers with different errors, although there must indeed be at least a sliver of overlap. I've made a zillion coding errors myself and recognize unintentional consequences. There's no reason warns should interrupt code flow like an error might, the theoretical potential exists. There's a problem with this driver and updating Current States. That is real, my wild-■■■-guess that it's predicted by warnings is not.
We have Debug, Warn and Info and IF these warnings are not pointing out a potential problem, then they should probably become Debug. In other words, if the warning is not something a user could fix on their own, then it's not the ideal message type in my mind. :slight_smile: So first, I'd appreciate that being "fixed" LOL
Second, if my report of the child component not updating correctly could be fixed too, I'd be even happier. :slight_smile: I don't actually know how I'd code up a driver to miss updating Current States, without a typo. snedEvent maybe? :smiley:
Sorry did not look close enough to see that other report was a different driver, just saw all the color stuff in the logs.
So I tested out my ZEN31 using my custom driver. Driver is using multiLevel v4, which I dont think is used very often, that could be part of it.
Code: https://raw.githubusercontent.com/jtp10181/Hubitat/main/Drivers/zooz/zooz-zen31-rgbw-dimmer.groovy
Post: [DRIVER] Zooz ZEN31 RGBW Dimmer Advanced
I can control the device just fine, but like you, no updates are making it back to the driver.
When I click refresh on my driver, a boatload of z-wave logs come through but almost nothing makes it to the driver. I also attempted the interview endpoint and with the zwave logs open I saw A LOT happening for a good 10 seconds so hat seems to he have worked fine. Still no change in the refresh.
2025-04-14 06:12:19.512 AMDRIVER all queues idle
2025-04-14 06:12:19.509 AMDRIVER « [Node 010] [REQ] [BridgeApplicationCommand] - │ RSSI: -50 dBm - └─[Security2CCMessageEncapsulation] - │ sequence number: 60 - │ security class: S2_Authenticated - └─[MeterCCReport] - meter type: Electric - scale: W - rate type: Consumed - value: 0.6 - time delta: 0 seconds
2025-04-14 06:12:19.505 AMCNTRLR [Node 010] [~] [Meter] value[66049]: 0.5 => 0.6 [Endpoint 0]
2025-04-14 06:12:19.502 AMCNTRLR [Node 010] [Meter] value[66049]: metadata updated [Endpoint 0]
2025-04-14 06:12:19.497 AMSERIAL » [ACK] (0x06)
2025-04-14 06:12:19.490 AMSERIAL « 0x012400a8000001000a169f033c007ee30e026d4f199e91c39ae3d61e4d04f8400 (38 bytes) - 0ce007f7f26
2025-04-14 06:12:19.465 AMDRIVER « [REQ] [SendDataBridge] - callback id: 213 - transmit status: OK, took 10 ms - routing attempts: 1 - protocol & route speed: Z-Wave, 100 kbit/s - routing scheme: LWR - ACK RSSI: -50 dBm - ACK channel no.: 0 - TX channel no.: 0
2025-04-14 06:12:19.461 AMSERIAL » [ACK] (0x06)
2025-04-14 06:12:19.457 AMSERIAL « 0x011d00a9d500000100ce7f7f7f7f00000300000000030100007f7f7f7f7f2f (31 bytes)
2025-04-14 06:12:19.451 AMDRIVER « [RES] [SendDataBridge] - was sent: true
2025-04-14 06:12:19.445 AMSERIAL » [ACK] (0x06)
2025-04-14 06:12:19.441 AMSERIAL « 0x010401a90152 (6 bytes)
2025-04-14 06:12:19.436 AMSERIAL « [ACK] (0x06)
2025-04-14 06:12:19.429 AMDRIVER » [Node 010] [REQ] [SendDataBridge] - │ source node id: 1 - │ transmit options: 0x25 - │ callback id: 213 - └─[Security2CCMessageEncapsulation] - │ sequence number: 33 - │ security class: S2_Authenticated - └─[MeterCCGet] - scale: W
2025-04-14 06:12:19.424 AMSERIAL » 0x011d00a90001000a0f9f032100f92d60893f013e9f9294fb2500000000d55d (31 bytes)
2025-04-14 06:12:19.414 AMDRIVER one or more queues busy
2025-04-14 06:12:19.400 AMDRIVER all queues idle
2025-04-14 06:12:19.392 AMDRIVER « [Node 010] [REQ] [BridgeApplicationCommand] - │ RSSI: -50 dBm - └─[Security2CCMessageEncapsulation] - │ sequence number: 59 - │ security class: S2_Authenticated - └─[MeterCCReport] - meter type: Electric - scale: W - rate type: Consumed - value: 0.5 - time delta: 0 seconds
2025-04-14 06:12:19.386 AMCNTRLR [Node 010] [~] [Meter] value[66049]: 0.6 => 0.5 [Endpoint 0]
2025-04-14 06:12:19.380 AMCNTRLR [Node 010] [Meter] value[66049]: metadata updated [Endpoint 0]
2025-04-14 06:12:19.373 AMSERIAL » [ACK] (0x06)
2025-04-14 06:12:19.366 AMSERIAL « 0x012400a8000001000a169f033b00f738db1b26e5f36e91d9fa5d2b32288b2acc0 (38 bytes) - 0ce007f7fe5
2025-04-14 06:12:19.339 AMDRIVER « [REQ] [SendDataBridge] - callback id: 212 - transmit status: OK, took 10 ms - routing attempts: 1 - protocol & route speed: Z-Wave, 100 kbit/s - routing scheme: LWR - ACK RSSI: -50 dBm - ACK channel no.: 0 - TX channel no.: 0
2025-04-14 06:12:19.335 AMSERIAL » [ACK] (0x06)
2025-04-14 06:12:19.327 AMSERIAL « 0x011d00a9d400000100ce7f7f7f7f00000300000000030100007f7f7f7f7f2e (31 bytes)
2025-04-14 06:12:19.317 AMSERIAL « 0x010401a90152 (6 bytes)
2025-04-14 06:12:19.315 AMSERIAL » [ACK] (0x06)
2025-04-14 06:12:19.309 AMSERIAL « [ACK] (0x06)
2025-04-14 06:12:19.302 AMDRIVER » [Node 010] [REQ] [SendDataBridge] - │ source node id: 1 - │ transmit options: 0x25 - │ callback id: 212 - └─[Security2CCMessageEncapsulation] - │ sequence number: 32 - │ security class: S2_Authenticated - └─[MeterCCGet] - scale: W
2025-04-14 06:12:19.296 AMSERIAL » 0x011d00a90001000a0f9f0320003ef78f89272bdcc022695c2500000000d4ca (31 bytes)
2025-04-14 06:12:19.285 AMDRIVER one or more queues busy
2025-04-14 06:12:19.255 AMDRIVER all queues idle
2025-04-14 06:12:19.248 AMDRIVER « [Node 010] [REQ] [BridgeApplicationCommand] - │ RSSI: -50 dBm - └─[Security2CCMessageEncapsulation] - │ sequence number: 58 - │ security class: S2_Authenticated - └─[ColorSwitchCCReport] - color component: Blue - current value: 0 - target value: 0 - duration: 0s
2025-04-14 06:12:19.233 AMCNTRLR [Node 010] [~] [Color Switch] currentColor: {"warmWhite":0,"red": [Endpoint 0] - 255,"green":0,"blue":0} => {"warmWhite":0,"red":255,"green":0,"blue":0}
2025-04-14 06:12:19.226 AMCNTRLR [Node 010] [~] [Color Switch] duration: {"value":0,"unit":"second [Endpoint 0] - s"} => {"value":0,"unit":"seconds"}
2025-04-14 06:12:19.218 AMCNTRLR [Node 010] [~] [Color Switch] targetColor[4]: 0 => 0 [Endpoint 0]
2025-04-14 06:12:19.209 AMCNTRLR [Node 010] [~] [Color Switch] currentColor[4]: 0 => 0 [Endpoint 0]
2025-04-14 06:12:19.186 AMSERIAL « 0x012000a8000001000a129f033a005c93bb33d811e2706c27eaab13e600ce007f7 (34 bytes) - fe5
2025-04-14 06:12:19.167 AMSERIAL » [ACK] (0x06)
2025-04-14 06:12:19.145 AMDRIVER « [RES] [SendDataBridge] - was sent: true
2025-04-14 06:12:19.137 AMSERIAL » [ACK] (0x06)
2025-04-14 06:12:19.134 AMSERIAL « 0x010401a90152 (6 bytes)
2025-04-14 06:12:19.126 AMSERIAL « [ACK] (0x06)
2025-04-14 06:12:19.113 AMDRIVER » [Node 010] [REQ] [SendDataBridge] - │ source node id: 1 - │ transmit options: 0x25 - │ callback id: 211 - └─[Security2CCMessageEncapsulation] - │ sequence number: 31 - │ security class: S2_Authenticated - └─[ColorSwitchCCGet] - color component: Blue
2025-04-14 06:12:19.102 AMSERIAL » 0x011d00a90001000a0f9f031f005d023f0b7ad4ab02a648e82500000000d350 (31 bytes)
2025-04-14 06:12:19.088 AMDRIVER one or more queues busy
2025-04-14 06:12:19.068 AMDRIVER all queues idle
2025-04-14 06:12:19.061 AMDRIVER « [Node 010] [REQ] [BridgeApplicationCommand] - │ RSSI: -50 dBm - └─[Security2CCMessageEncapsulation] - │ sequence number: 57 - │ security class: S2_Authenticated - └─[ColorSwitchCCReport] - color component: Blue - current value: 0 - target value: 0 - duration: 0s
2025-04-14 06:12:19.051 AMCNTRLR [Node 010] [~] [Color Switch] targetColor: {"warmWhite":0,"red":2 [Endpoint 0] - 55,"green":0,"blue":0} => {"warmWhite":0,"red":255,"green":0,"blue":0}
2025-04-14 06:12:19.052 AMCNTRLR [Node 010] [~] [Color Switch] hexColor: "ff0000" => "ff0000" [Endpoint 0]
2025-04-14 06:12:19.038 AMCNTRLR [Node 010] [~] [Color Switch] targetColor[4]: 0 => 0 [Endpoint 0]
2025-04-14 06:12:19.043 AMCNTRLR [Node 010] [~] [Color Switch] currentColor: {"warmWhite":0,"red": [Endpoint 0] - 255,"green":0,"blue":0} => {"warmWhite":0,"red":255,"green":0,"blue":0}
2025-04-14 06:12:19.040 AMCNTRLR [Node 010] [~] [Color Switch] duration: {"value":0,"unit":"second [Endpoint 0] - s"} => {"value":0,"unit":"seconds"}
2025-04-14 06:12:19.035 AMCNTRLR [Node 010] [~] [Color Switch] currentColor[4]: 0 => 0 [Endpoint 0]
2025-04-14 06:12:19.027 AMSERIAL » [ACK] (0x06)
2025-04-14 06:12:19.017 AMSERIAL « 0x012000a8000001000a129f033900953bab6f17d3554de8299cae7a6f00ce007f7 (34 bytes) - f55
2025-04-14 06:12:19.007 AMDRIVER « [REQ] [SendDataBridge] - callback id: 210 - transmit status: OK, took 10 ms - routing attempts: 1 - protocol & route speed: Z-Wave, 100 kbit/s - routing scheme: LWR - ACK RSSI: -50 dBm - ACK channel no.: 0 - TX channel no.: 0
2025-04-14 06:12:18.998 AMSERIAL » [ACK] (0x06)
2025-04-14 06:12:18.991 AMSERIAL « 0x011d00a9d200000100ce7f7f7f7f00000300000000030100007f7f7f7f7f28 (31 bytes)
2025-04-14 06:12:18.982 AMDRIVER « [RES] [SendDataBridge] - was sent: true
2025-04-14 06:12:18.973 AMSERIAL » [ACK] (0x06)
2025-04-14 06:12:18.962 AMSERIAL « 0x010401a90152 (6 bytes)
2025-04-14 06:12:18.950 AMSERIAL « [ACK] (0x06)
2025-04-14 06:12:18.940 AMDRIVER » [Node 010] [REQ] [SendDataBridge] - │ source node id: 1 - │ transmit options: 0x25 - │ callback id: 210 - └─[Security2CCMessageEncapsulation] - │ sequence number: 30 - │ security class: S2_Authenticated - └─[ColorSwitchCCGet] - color component: Blue
2025-04-14 06:12:18.933 AMSERIAL » 0x011d00a90001000a0f9f031e00426eb9a425a65e9f3ba60d2500000000d2d9 (31 bytes)
2025-04-14 06:12:18.918 AMDRIVER one or more queues busy
2025-04-14 06:12:18.908 AMDRIVER all queues idle
2025-04-14 06:12:18.896 AMDRIVER « [Node 010] [REQ] [BridgeApplicationCommand] - │ RSSI: -50 dBm - └─[Security2CCMessageEncapsulation] - │ sequence number: 56 - │ security class: S2_Authenticated - └─[ColorSwitchCCReport] - color component: Green - current value: 0 - target value: 0 - duration: 0s
2025-04-14 06:12:18.884 AMCNTRLR [Node 010] [~] [Color Switch] hexColor: "ff0000" => "ff0000" [Endpoint 0]
2025-04-14 06:12:18.873 AMCNTRLR [Node 010] [~] [Color Switch] targetColor: {"warmWhite":0,"red":2 [Endpoint 0] - 55,"green":0,"blue":0} => {"warmWhite":0,"red":255,"green":0,"blue":0}
2025-04-14 06:12:18.854 AMCNTRLR [Node 010] [~] [Color Switch] duration: {"value":0,"unit":"second [Endpoint 0] - s"} => {"value":0,"unit":"seconds"}
2025-04-14 06:12:18.846 AMCNTRLR [Node 010] [~] [Color Switch] targetColor[3]: 0 => 0 [Endpoint 0]
2025-04-14 06:12:18.838 AMCNTRLR [Node 010] [~] [Color Switch] currentColor[3]: 0 => 0 [Endpoint 0]
2025-04-14 06:12:18.823 AMSERIAL » [ACK] (0x06)
2025-04-14 06:12:18.810 AMSERIAL « 0x012000a8000001000a129f033800c3c4e63b54f11c0684b265b9704f00ce007f7 (34 bytes) - fb4
2025-04-14 06:12:18.795 AMDRIVER « [REQ] [SendDataBridge] - callback id: 209 - transmit status: OK, took 10 ms - routing attempts: 1 - protocol & route speed: Z-Wave, 100 kbit/s - routing scheme: LWR - ACK RSSI: -50 dBm - ACK channel no.: 0 - TX channel no.: 0
2025-04-14 06:12:18.784 AMSERIAL » [ACK] (0x06)
2025-04-14 06:12:18.778 AMSERIAL « 0x011d00a9d100000100ce7f7f7f7f00000300000000030100007f7f7f7f7f2b (31 bytes)
2025-04-14 06:12:18.762 AMDRIVER « [RES] [SendDataBridge] - was sent: true
2025-04-14 06:12:18.754 AMSERIAL » [ACK] (0x06)
2025-04-14 06:12:18.748 AMSERIAL « 0x010401a90152 (6 bytes)
2025-04-14 06:12:18.737 AMSERIAL « [ACK] (0x06)
2025-04-14 06:12:18.727 AMDRIVER » [Node 010] [REQ] [SendDataBridge] - │ source node id: 1 - │ transmit options: 0x25 - │ callback id: 209 - └─[Security2CCMessageEncapsulation] - │ sequence number: 29 - │ security class: S2_Authenticated - └─[ColorSwitchCCGet] - color component: Green
2025-04-14 06:12:18.721 AMSERIAL » 0x011d00a90001000a0f9f031d00a592d9b045490f50a8b3632500000000d14f (31 bytes)
2025-04-14 06:12:18.712 AMDRIVER one or more queues busy
2025-04-14 06:12:18.677 AMCNTRLR [Node 010] [~] [Color Switch] hexColor: "ff0000" => "ff0000" [Endpoint 0]
2025-04-14 06:12:18.668 AMCNTRLR [Node 010] [~] [Color Switch] targetColor: {"warmWhite":0,"red":2 [Endpoint 0] - 55,"green":0,"blue":0} => {"warmWhite":0,"red":255,"green":0,"blue":0}
2025-04-14 06:12:18.662 AMCNTRLR [Node 010] [~] [Color Switch] currentColor: {"warmWhite":0,"red": [Endpoint 0] - 255,"green":0,"blue":0} => {"warmWhite":0,"red":255,"green":0,"blue":0}
2025-04-14 06:12:18.655 AMCNTRLR [Node 010] [~] [Color Switch] duration: {"value":0,"unit":"second [Endpoint 0] - s"} => {"value":0,"unit":"seconds"}
2025-04-14 06:12:18.643 AMCNTRLR [Node 010] [~] [Color Switch] targetColor[3]: 0 => 0 [Endpoint 0]
2025-04-14 06:12:18.632 AMCNTRLR [Node 010] [~] [Color Switch] currentColor[3]: 0 => 0 [Endpoint 0]
2025-04-14 06:12:18.617 AMSERIAL » [ACK] (0x06)
2025-04-14 06:12:18.603 AMSERIAL « 0x012000a8000001000a129f033700ba3b15e9061ffb0f65b3c75b6dbd00ce007f7 (34 bytes) - f01
2025-04-14 06:12:18.592 AMDRIVER « [REQ] [SendDataBridge] - callback id: 208 - transmit status: OK, took 10 ms - routing attempts: 1 - protocol & route speed: Z-Wave, 100 kbit/s - routing scheme: LWR - ACK RSSI: -50 dBm - ACK channel no.: 0 - TX channel no.: 0
2025-04-14 06:12:18.584 AMSERIAL » [ACK] (0x06)
2025-04-14 06:12:18.574 AMSERIAL « 0x011d00a9d000000100ce7f7f7f7f00000300000000030100007f7f7f7f7f2a (31 bytes)
2025-04-14 06:12:18.566 AMDRIVER « [RES] [SendDataBridge] - was sent: true
2025-04-14 06:12:18.559 AMSERIAL » [ACK] (0x06)
2025-04-14 06:12:18.555 AMSERIAL « [ACK] (0x06)
2025-04-14 06:12:18.538 AMDRIVER » [Node 010] [REQ] [SendDataBridge] - │ source node id: 1 - │ transmit options: 0x25 - │ callback id: 208 - └─[Security2CCMessageEncapsulation] - │ sequence number: 28 - │ security class: S2_Authenticated - └─[ColorSwitchCCGet] - color component: Green
2025-04-14 06:12:18.527 AMSERIAL » 0x011d00a90001000a0f9f031c000df8935957fbe52b1ce64b2500000000d0d6 (31 bytes)
2025-04-14 06:12:18.504 AMDRIVER one or more queues busy
2025-04-14 06:12:18.415 AMDRIVER all queues idle
2025-04-14 06:12:18.407 AMDRIVER « [Node 010] [REQ] [BridgeApplicationCommand] - │ RSSI: -50 dBm - └─[Security2CCMessageEncapsulation] - │ sequence number: 54 - │ security class: S2_Authenticated - └─[ColorSwitchCCReport] - color component: Red - current value: 255 - target value: 255 - duration: 0s
2025-04-14 06:12:18.395 AMCNTRLR [Node 010] [~] [Color Switch] targetColor: {"warmWhite":0,"red":2 [Endpoint 0] - 55,"green":0,"blue":0} => {"warmWhite":0,"red":255,"green":0,"blue":0}
2025-04-14 06:12:18.398 AMCNTRLR [Node 010] [~] [Color Switch] hexColor: "ff0000" => "ff0000" [Endpoint 0]
2025-04-14 06:12:18.394 AMCNTRLR [Node 010] [~] [Color Switch] currentColor: {"warmWhite":0,"red": [Endpoint 0] - 255,"green":0,"blue":0} => {"warmWhite":0,"red":255,"green":0,"blue":0}
2025-04-14 06:12:18.392 AMCNTRLR [Node 010] [~] [Color Switch] duration: {"value":0,"unit":"second [Endpoint 0] - s"} => {"value":0,"unit":"seconds"}
2025-04-14 06:12:18.377 AMCNTRLR [Node 010] [~] [Color Switch] currentColor[2]: 255 => 255 [Endpoint 0]
2025-04-14 06:12:18.372 AMSERIAL » [ACK] (0x06)
2025-04-14 06:12:18.357 AMSERIAL « 0x012000a8000001000a129f033600b3b69fb6b3a8386a263abd40bed900ce007f7 (34 bytes) - fe9
2025-04-14 06:12:18.337 AMDRIVER « [REQ] [SendDataBridge] - callback id: 207 - transmit status: OK, took 10 ms - routing attempts: 1 - protocol & route speed: Z-Wave, 100 kbit/s - routing scheme: LWR - ACK RSSI: -50 dBm - ACK channel no.: 0 - TX channel no.: 0
2025-04-14 06:12:18.333 AMSERIAL » [ACK] (0x06)
2025-04-14 06:12:18.324 AMSERIAL « 0x011d00a9cf00000100ce7f7f7f7f00000300000000030100007f7f7f7f7f35 (31 bytes)
2025-04-14 06:12:18.321 AMSERIAL » [ACK] (0x06)
2025-04-14 06:12:18.318 AMDRIVER « [RES] [SendDataBridge] - was sent: true
2025-04-14 06:12:18.311 AMSERIAL « 0x010401a90152 (6 bytes)
2025-04-14 06:12:18.302 AMSERIAL « [ACK] (0x06)
2025-04-14 06:12:18.296 AMDRIVER » [Node 010] [REQ] [SendDataBridge] - │ source node id: 1 - │ transmit options: 0x25 - │ callback id: 207 - └─[Security2CCMessageEncapsulation] - │ sequence number: 27 - │ security class: S2_Authenticated - └─[ColorSwitchCCGet] - color component: Red
2025-04-14 06:12:18.291 AMSERIAL » 0x011d00a90001000a0f9f031b003959a582d369bb831557dd2500000000cf78 (31 bytes)
2025-04-14 06:12:18.282 AMDRIVER one or more queues busy
2025-04-14 06:12:18.267 AMDRIVER all queues idle
2025-04-14 06:12:18.263 AMCNTRLR [Node 010] [~] [Color Switch] hexColor: "ff0000" => "ff0000" [Endpoint 0]
2025-04-14 06:12:18.259 AMCNTRLR [Node 010] [~] [Color Switch] targetColor: {"warmWhite":0,"red":2 [Endpoint 0] - 55,"green":0,"blue":0} => {"warmWhite":0,"red":255,"green":0,"blue":0}
2025-04-14 06:12:18.254 AMCNTRLR [Node 010] [~] [Color Switch] currentColor: {"warmWhite":0,"red": [Endpoint 0] - 255,"green":0,"blue":0} => {"warmWhite":0,"red":255,"green":0,"blue":0}
2025-04-14 06:12:18.250 AMCNTRLR [Node 010] [~] [Color Switch] duration: {"value":0,"unit":"second [Endpoint 0] - s"} => {"value":0,"unit":"seconds"}
2025-04-14 06:12:18.246 AMCNTRLR [Node 010] [~] [Color Switch] targetColor[2]: 255 => 255 [Endpoint 0]
2025-04-14 06:12:18.240 AMCNTRLR [Node 010] [~] [Color Switch] currentColor[2]: 255 => 255 [Endpoint 0]
2025-04-14 06:12:18.234 AMSERIAL » [ACK] (0x06)
2025-04-14 06:12:18.228 AMSERIAL « 0x012000a8000001000a129f0335000cafc931a8c9b83e90aef24124bb00ce007f7 (34 bytes) - fa7
2025-04-14 06:12:18.203 AMDRIVER « [REQ] [SendDataBridge] - callback id: 206 - transmit status: OK, took 10 ms - routing attempts: 1 - protocol & route speed: Z-Wave, 100 kbit/s - routing scheme: LWR - ACK RSSI: -50 dBm - ACK channel no.: 0 - TX channel no.: 0
2025-04-14 06:12:18.199 AMSERIAL » [ACK] (0x06)
2025-04-14 06:12:18.193 AMSERIAL « 0x011d00a9ce00000100ce7f7f7f7f00000300000000030100007f7f7f7f7f34 (31 bytes)
2025-04-14 06:12:18.186 AMDRIVER « [RES] [SendDataBridge] - was sent: true
2025-04-14 06:12:18.182 AMSERIAL » [ACK] (0x06)
2025-04-14 06:12:18.178 AMSERIAL « 0x010401a90152 (6 bytes)
2025-04-14 06:12:18.173 AMSERIAL « [ACK] (0x06)
2025-04-14 06:12:18.168 AMDRIVER » [Node 010] [REQ] [SendDataBridge] - │ source node id: 1 - │ transmit options: 0x25 - │ callback id: 206 - └─[Security2CCMessageEncapsulation] - │ sequence number: 26 - │ security class: S2_Authenticated - └─[ColorSwitchCCGet] - color component: Red
2025-04-14 06:12:18.161 AMSERIAL » 0x011d00a90001000a0f9f031a00d797878ba87899fcc09a862500000000ce07 (31 bytes)
2025-04-14 06:12:18.155 AMDRIVER one or more queues busy
2025-04-14 06:12:18.061 AMDRIVER « [Node 010] [REQ] [BridgeApplicationCommand] - │ RSSI: -50 dBm - └─[Security2CCMessageEncapsulation] - │ sequence number: 52 - │ security class: S2_Authenticated - └─[ColorSwitchCCReport] - color component: Warm White - current value: 0 - target value: 0 - duration: 0s
2025-04-14 06:12:18.052 AMCNTRLR [Node 010] [~] [Color Switch] currentColor: {"warmWhite":0,"red": [Endpoint 0] - 255,"green":0,"blue":0} => {"warmWhite":0,"red":255,"green":0,"blue":0}
2025-04-14 06:12:18.047 AMCNTRLR [Node 010] [~] [Color Switch] targetColor[0]: 0 => 0 [Endpoint 0]
2025-04-14 06:12:18.042 AMCNTRLR [Node 010] [~] [Color Switch] currentColor[0]: 0 => 0 [Endpoint 0]
2025-04-14 06:12:18.035 AMSERIAL » [ACK] (0x06)
2025-04-14 06:12:18.029 AMSERIAL « 0x012000a8000001000a129f0334002fee1e19c6de7001136a0aa4a7e700ce007f7 (34 bytes) - f30
2025-04-14 06:12:17.997 AMDRIVER « [REQ] [SendDataBridge] - callback id: 205 - transmit status: OK, took 10 ms - routing attempts: 1 - protocol & route speed: Z-Wave, 100 kbit/s - routing scheme: LWR - ACK RSSI: -50 dBm - ACK channel no.: 0 - TX channel no.: 0
2025-04-14 06:12:17.992 AMSERIAL » [ACK] (0x06)
2025-04-14 06:12:17.988 AMSERIAL « 0x011d00a9cd00000100ce7f7f7f7f00000300000000030100007f7f7f7f7f37 (31 bytes)
2025-04-14 06:12:17.985 AMDRIVER « [RES] [SendDataBridge] - was sent: true
2025-04-14 06:12:17.980 AMSERIAL » [ACK] (0x06)
2025-04-14 06:12:17.976 AMSERIAL « 0x010401a90152 (6 bytes)
2025-04-14 06:12:17.970 AMSERIAL « [ACK] (0x06)
2025-04-14 06:12:17.964 AMDRIVER » [Node 010] [REQ] [SendDataBridge] - │ source node id: 1 - │ transmit options: 0x25 - │ callback id: 205 - └─[Security2CCMessageEncapsulation] - │ sequence number: 25 - │ security class: S2_Authenticated - └─[ColorSwitchCCGet] - color component: Warm White
2025-04-14 06:12:17.958 AMSERIAL » 0x011d00a90001000a0f9f03190044ffbbfe4a834aac06654c2500000000cddc (31 bytes)
2025-04-14 06:12:17.948 AMDRIVER one or more queues busy
2025-04-14 06:12:17.933 AMDRIVER all queues idle
2025-04-14 06:12:17.930 AMDRIVER « [Node 010] [REQ] [BridgeApplicationCommand] - │ RSSI: -50 dBm - └─[Security2CCMessageEncapsulation] - │ sequence number: 51 - │ security class: S2_Authenticated - └─[ColorSwitchCCReport] - color component: Warm White - current value: 0 - target value: 0 - duration: 0s
2025-04-14 06:12:17.924 AMCNTRLR [Node 010] [~] [Color Switch] targetColor: {"warmWhite":0,"red":2 [Endpoint 0] - 55,"green":0,"blue":0} => {"warmWhite":0,"red":255,"green":0,"blue":0}
2025-04-14 06:12:17.919 AMCNTRLR [Node 010] [~] [Color Switch] currentColor: {"warmWhite":0,"red": [Endpoint 0] - 255,"green":0,"blue":0} => {"warmWhite":0,"red":255,"green":0,"blue":0}
2025-04-14 06:12:17.913 AMCNTRLR [Node 010] [~] [Color Switch] duration: {"value":0,"unit":"second [Endpoint 0] - s"} => {"value":0,"unit":"seconds"}
2025-04-14 06:12:17.909 AMCNTRLR [Node 010] [~] [Color Switch] targetColor[0]: 0 => 0 [Endpoint 0]
2025-04-14 06:12:17.902 AMCNTRLR [Node 010] [~] [Color Switch] currentColor[0]: 0 => 0 [Endpoint 0]
2025-04-14 06:12:17.896 AMSERIAL » [ACK] (0x06)
2025-04-14 06:12:17.890 AMSERIAL « 0x012000a8000001000a129f033300edb03cee0245722241d7009f76fe00ce007f7 (34 bytes) - f16
2025-04-14 06:12:17.864 AMDRIVER « [REQ] [SendDataBridge] - callback id: 204 - transmit status: OK, took 10 ms - routing attempts: 1 - protocol & route speed: Z-Wave, 100 kbit/s - routing scheme: LWR - ACK RSSI: -50 dBm - ACK channel no.: 0 - TX channel no.: 0
2025-04-14 06:12:17.858 AMSERIAL » [ACK] (0x06)
2025-04-14 06:12:17.854 AMSERIAL « 0x011d00a9cc00000100ce7f7f7f7f00000300000000030100007f7f7f7f7f36 (31 bytes)
2025-04-14 06:12:17.847 AMDRIVER « [RES] [SendDataBridge] - was sent: true
2025-04-14 06:12:17.843 AMSERIAL « 0x010401a90152 (6 bytes)
2025-04-14 06:12:17.834 AMSERIAL « [ACK] (0x06)
2025-04-14 06:12:17.831 AMDRIVER » [Node 010] [REQ] [SendDataBridge] - │ source node id: 1 - │ transmit options: 0x25 - │ callback id: 204 - └─[Security2CCMessageEncapsulation] - │ sequence number: 24 - │ security class: S2_Authenticated - └─[ColorSwitchCCGet] - color component: Warm White
2025-04-14 06:12:17.823 AMSERIAL » 0x011d00a90001000a0f9f03180075786eaf4f63000831fa412500000000cc40 (31 bytes)
2025-04-14 06:12:17.813 AMDRIVER one or more queues busy
2025-04-14 06:12:17.714 AMDRIVER all queues idle
2025-04-14 06:12:17.709 AMDRIVER « [Node 010] [REQ] [BridgeApplicationCommand] - │ RSSI: -50 dBm - └─[Security2CCMessageEncapsulation] - │ sequence number: 50 - │ security class: S2_Authenticated - └─[MultilevelSwitchCCReport] - current value: 99 - target value: 99 - duration: 0s
2025-04-14 06:12:17.704 AMCNTRLR [Node 010] [~] [Multilevel Switch] currentValue: 99 => 99 [Endpoint 0]
2025-04-14 06:12:17.700 AMCNTRLR [Node 010] [~] [Multilevel Switch] duration: {"value":0,"unit":"s [Endpoint 0] - econds"} => {"value":0,"unit":"seconds"}
2025-04-14 06:12:17.696 AMCNTRLR [Node 010] [~] [Multilevel Switch] targetValue: 99 => 99 [Endpoint 0]
2025-04-14 06:12:17.691 AMSERIAL » [ACK] (0x06)
2025-04-14 06:12:17.685 AMSERIAL « 0x011f00a8000001000a119f033200caf0f774be0a33be975a4896cf00ce007f7f6 (33 bytes) - e
2025-04-14 06:12:17.661 AMDRIVER « [REQ] [SendDataBridge] - callback id: 203 - transmit status: OK, took 10 ms - routing attempts: 1 - protocol & route speed: Z-Wave, 100 kbit/s - routing scheme: LWR - ACK RSSI: -50 dBm - ACK channel no.: 0 - TX channel no.: 0
2025-04-14 06:12:17.655 AMSERIAL » [ACK] (0x06)
2025-04-14 06:12:17.651 AMSERIAL « 0x011d00a9cb00000100ce7f7f7f7f00000300000000030100007f7f7f7f7f31 (31 bytes)
2025-04-14 06:12:17.644 AMDRIVER « [RES] [SendDataBridge] - was sent: true
2025-04-14 06:12:17.642 AMSERIAL » [ACK] (0x06)
2025-04-14 06:12:17.637 AMSERIAL « 0x010401a90152 (6 bytes)
2025-04-14 06:12:17.632 AMSERIAL « [ACK] (0x06)
2025-04-14 06:12:17.626 AMDRIVER » [Node 010] [REQ] [SendDataBridge] - │ source node id: 1 - │ transmit options: 0x25 - │ callback id: 203 - └─[Security2CCMessageEncapsulation] - │ sequence number: 23 - │ security class: S2_Authenticated - └─[MultilevelSwitchCCGet]
2025-04-14 06:12:17.620 AMSERIAL » 0x011c00a90001000a0e9f031700aeeb1b15340684273f2f2500000000cbe0 (30 bytes)
2025-04-14 06:12:17.611 AMDRIVER one or more queues busy
2025-04-14 06:12:17.593 AMDRIVER all queues idle
2025-04-14 06:12:17.592 AMDRIVER « [Node 010] [REQ] [BridgeApplicationCommand] - │ RSSI: -50 dBm - └─[Security2CCMessageEncapsulation] - │ sequence number: 49 - │ security class: S2_Authenticated - └─[MultilevelSwitchCCReport] - current value: 99 - target value: 99 - duration: 0s
2025-04-14 06:12:17.588 AMCNTRLR [Node 010] [~] [Multilevel Switch] currentValue: 99 => 99 [Endpoint 0]
2025-04-14 06:12:17.584 AMCNTRLR [Node 010] [~] [Multilevel Switch] duration: {"value":0,"unit":"s [Endpoint 0] - econds"} => {"value":0,"unit":"seconds"}
2025-04-14 06:12:17.579 AMCNTRLR [Node 010] [~] [Multilevel Switch] targetValue: 99 => 99 [Endpoint 0]
2025-04-14 06:12:17.574 AMSERIAL » [ACK] (0x06)
2025-04-14 06:12:17.567 AMSERIAL « 0x011f00a8000001000a119f0331006d1b7457958517c1f6bde3d9d500ce007f7f0 (33 bytes) - 6
2025-04-14 06:12:17.541 AMDRIVER « [REQ] [SendDataBridge] - callback id: 202 - transmit status: OK, took 10 ms - routing attempts: 1 - protocol & route speed: Z-Wave, 100 kbit/s - routing scheme: LWR - ACK RSSI: -50 dBm - ACK channel no.: 0 - TX channel no.: 0
2025-04-14 06:12:17.535 AMSERIAL » [ACK] (0x06)
2025-04-14 06:12:17.531 AMSERIAL « 0x011d00a9ca00000100ce7f7f7f7f00000300000000030100007f7f7f7f7f30 (31 bytes)
2025-04-14 06:12:17.522 AMSERIAL » [ACK] (0x06)
2025-04-14 06:12:17.524 AMDRIVER « [RES] [SendDataBridge] - was sent: true
2025-04-14 06:12:17.518 AMSERIAL « 0x010401a90152 (6 bytes)
2025-04-14 06:12:17.508 AMDRIVER » [Node 010] [REQ] [SendDataBridge] - │ source node id: 1 - │ transmit options: 0x25 - │ callback id: 202 - └─[Security2CCMessageEncapsulation] - │ sequence number: 22 - │ security class: S2_Authenticated - └─[MultilevelSwitchCCGet]
2025-04-14 06:12:17.502 AMSERIAL » 0x011c00a90001000a0e9f031600363c6a4d51ea4521b18a2500000000cae3 (30 bytes)
2025-04-14 06:12:17.492 AMDRIVER one or more queues busy
2025-04-14 06:12:17.161 AMDRIVER all queues idle
2025-04-14 06:12:17.087 AMDRIVER « [Node 010] [REQ] [BridgeApplicationCommand] - │ RSSI: -50 dBm - └─[Security2CCMessageEncapsulation] - │ sequence number: 48 - │ security class: S2_Authenticated - └─[ConfigurationCCReport] - parameter #: 157 - value size: 1 - value: 0
2025-04-14 06:12:17.076 AMCNTRLR [Node 010] [~] [Configuration] 157: 0 => 0 [Endpoint 0]
2025-04-14 06:12:17.065 AMSERIAL » [ACK] (0x06)
2025-04-14 06:12:17.057 AMSERIAL « 0x011f00a8000001000a119f0330004ac7ca1cd199494071851bf9de00ce007f7fe (33 bytes) - 2
2025-04-14 06:12:17.045 AMDRIVER « [REQ] [SendDataBridge] - callback id: 201 - transmit status: OK, took 10 ms - routing attempts: 1 - protocol & route speed: Z-Wave, 100 kbit/s - routing scheme: LWR - ACK RSSI: -50 dBm - ACK channel no.: 0 - TX channel no.: 0
2025-04-14 06:12:17.036 AMSERIAL » [ACK] (0x06)
2025-04-14 06:12:17.033 AMSERIAL « 0x011d00a9c900000100ce7f7f7f7f00000300000000030100007f7f7f7f7f33 (31 bytes)
2025-04-14 06:12:17.027 AMDRIVER « [RES] [SendDataBridge] - was sent: true
2025-04-14 06:12:17.022 AMSERIAL » [ACK] (0x06)
2025-04-14 06:12:17.016 AMSERIAL « 0x010401a90152 (6 bytes)
2025-04-14 06:12:17.007 AMSERIAL « [ACK] (0x06)
2025-04-14 06:12:17.001 AMDRIVER » [Node 010] [REQ] [SendDataBridge] - │ source node id: 1 - │ transmit options: 0x25 - │ callback id: 201 - └─[Security2CCMessageEncapsulation] - │ sequence number: 21 - │ security class: S2_Authenticated - └─[ConfigurationCCGet] - parameter #: 157
2025-04-14 06:12:16.995 AMSERIAL » 0x011d00a90001000a0f9f0315001c9f517f76fd326c2604d52500000000c9a5 (31 bytes)
2025-04-14 06:12:16.983 AMDRIVER one or more queues busy
2025-04-14 06:12:14.050 AMDRIVER all queues idle
2025-04-14 06:12:14.034 AMDRIVER « [RES] [GetBackgroundRSSI] - channel 0: -97 dBm - channel 1: -101 dBm - channel 2: -101 dBm - channel 3: -93 dBm
2025-04-14 06:12:14.028 AMSERIAL » [ACK] (0x06)
2025-04-14 06:12:14.024 AMSERIAL « 0x0107013b9f9b9ba3fe (9 bytes)
2025-04-14 06:12:14.023 AMSERIAL « [ACK] (0x06)
2025-04-14 06:12:14.016 AMDRIVER » [REQ] [GetBackgroundRSSI]
2025-04-14 06:12:14.002 AMSERIAL » 0x0103003bc7 (5 bytes)
2025-04-14 06:12:13.989 AMDRIVER one or more queues busy
