After updating from 2.4.0.151 to 2.4.1.152 yesterday (and continuing on with .153), I have noticed that all my Aqara Zigbee Temp/Humidity sensors using the built-in driver (Aqara Zigbee Weather Sensor) have stopped reporting temperature, although they still report humidity just fine.
Also @mike.maxwell , I was wondering if you would consider adding tenths to the humidity reports (ie 24.x instead of 24).
*Edit
(I really thought I posted this in Built-in Drivers section. Sorry to have posted this in the wrong place)
There have been two other reports of this. And one person noted that resetting and re-pairing the device fixed it. Since these are zigbee devices, they slot back into their existing device-id.
This has been discussed once before (for all relative humidity sensors), and the conclusion was that tenths didn’t matter for RH. Anyway, here's where that discussion was:
Yeah, I get that, and it's true. The only reason I want tenths is because it makes the graphs look smoother instead of like staircases. And, because I know the sensor already reports decimals, all one would have to do is change the attribute type from integer to decimal to accomplish the change..
Cool. I was gonna report back that reconnecting them didn't work - still not getting temp readings after reconnecting every single one (13 in all). Glad to see it's been confirmed and getting fixed.
