Have tried several times to update my C8 from 2.3.9.147 to 2.3.9.150 and it get to 4% after 20 minutes the update fail.
have restarted and tried again same result. any suggestions?
This will sound strange, but go to your network settings and click on Ethernet Settings. If it says Auto-negotiated change it to Fixed 100Mbps, if it says Fixed 100Mbps change it to Auto-negotiated, and then retry.
9 posts were split to a new topic: Stuck on update 2.3.9.116
thank you this worked
I had a flashing alert in the upper corner this morning when check out my Hubitat, so I clicked through the links to update. It kept saying no update available, so a quick reboot of the hub and it was finally able to see the latest update.
Not sure if this will help anyone else.
You can also always click Check Update button which will force it
I think I tried that as well and it still didn't work. Thankfully the reboot button was also on that same settings page.
Also duplex matters too. If trying fixed, try half and full duplex to see which one works best. Full duplex is of course faster, since it allows Ethernet to send and receive at the same time, but when using fixed settings, itβs important they match perfectly. Auto negotiate is a poor standard that isnβt always implemented the same, and can sometime result in one side negotiating 100 full and the other negotiating 100 half.
