[2.3.6.146]Ring Gen2 Keypad error on inclusion[C8]
On inclusion of the Ring Gen2 Keypad I am seeing the below error in the logs:
Summary
The keypad responds to the commands on the device details page, however it does not seem to accept commands directly from the keypad. I configured Lock Code Manager and HSM. Using Arm within Hubitat Safety monitor will activate the away delay sound and armed status after the delay (on the keypad). Disarm within HSM will also say Disarmed on the keypad.
The main issue I am seeing is that the keypad input is not accepted.
Other pictures that may or may not be useful:
Summary
I have excluded this keypad and re-included it several times with the same results.
@bcopeland - This driver issue doesn't seem to be limited to the latest beta. I rolled back to 2.3.5.152 and excluded and then included the Ring Gen2 Keypad and get the following message in the logs:
Summary
This issue is using the built in driver, not a 3rd party driver.
@support_team - Please let me know if any further details are needed, or if I should try anything. WIth the error on inclusion I imagine I will need to await a fix to the driver in a future update.
I see the problem and will push a fix.. Thanks
Thank you Brian. Very much appreciated.
This topic was automatically closed 90 days after the last reply. New replies are no longer allowed.
