Release says it add the Yolax Driver but I can not seem to find it in the new update. Do I need to install this or something ?
Release 2.3.5.152 Available
Changes from 2.3.5.146
New Drivers
- Yolax Zigbee Shade
- Smartwings Zigbee Shade
New Drivers
Have you installed .152? "Yolax..." shows up as an available Device-Type driver for me.
If you're still on .146, it won't be available there.
As @hydro311 noted, if you are on update 152, your should see yolax drivers. But also, not all new device support includes a driver specific for the device. It could also have been the case that the two new Zigbee Shade drivers were implemented with a single new generic Zigbee Shade controller driver that supports multiple brands. This is very common for Z-Wave devices supported by HE.
Yes installed .152
No Yolax
That's odd then... Something is amiss with .152 -- you're missing that driver, and I'm missing the new Color Animations app. Strange.
and i have the color app but every possible thing i try it's only giving a error and points me to the logs... where i can find this...
After the update, I see the Yolax Zigbee Shade driver… but I can’t help but wonder…
Is it supposed to be Yoolax instead of Yolax? Or is there a different device altogether with such a similar name?
Searching online, I can only find Yoolax. I cannot fin a Yolax. So Yolax is probably a typo
Strange. Can you restore from yesterday's backup? This will insure a clean database. Then can you roll back to the previous platform install (yourhubip:8081) and then re upgrade?
Hi all - tried the new system driver that came with the new release 2.3.5.152. "Yoolax" driver and came up with an "unknown" in the Dashboard when I selected the Shade template. Wondering if anyone knew anything about it, why it might be incompatible. Attached a screen shot.
Didnt work, still not there
