But! I have in the process of updating the system i have replaced 2 hubs.
Restored the original databases, rebooted.
Having a hard time getting them to back online with hubmesh.
Hub IP's are appropriate on the settings/hubmesh pages.
Worse than that, i have done this several times, and have apparently forgotten the trick.
I know there is a way, just cannot remember it.
Darn system runs dependably enough, i dont get enough practice...
Generally if you give HubMesh a few minutes to exchange data everything will come back online. Do note that all hubs will need to be on .138 due to recent changes.
Yes to both points, @thebearmay.
24 hours had passed.
The .138 release notes i did read and heed.
In the process i changed 2xC4 to 2xC7.
Restored .123 databases.
These are the 2 that are not "meshing".
I have done similar in the past.
All are on .138.
Yes, comma separated.
They will also share information about other nodes they "know" about, e.g. if hub A sees hub B, and hub B seees hub C, B should share the location of C to A.
