As you saw in my list of choices, I didn't have a Gas detector to select even though I have set up a Heinman Gas detector (with system provided driver).
Also, since we are on the topic of HSM, does the custom rule notification work?
That is, I have a water sensor which shows wet, and I have a HSM rule which monitors that sensor. The log shows that the sensor is wet, yet it wasn't triggered by the HSM rule. The rule is armed.
Isn't it supposed to work that way?
I can send you screenshots, if necessary.
It appears that HSM Rule has the wrong event subscription for Gas Detector, and that will be fixed. It does work for sending notifications, including for water sensor.
This works for me as expected, not alerting until 1 minute after the water.wet event, and only alerting once within the time period.
Hit Done in the rule to wipe out all schedules, etc. Then trip one of the water sensors, then look at the Scheduled Jobs at the bottom of the App Status page (be sure this is refreshed after the wet event happens). You should see a job to run doAlert in one minute, and one to clearNotify in 10 minutes.
