[2.3.1.138] Motion Lighting Error with scene activation (take 2)
Hi, this is similar to this thread.
Rather than hijacking someone else's thread, I created a new one instead.
After all, mine is based on the latest firmware too.
I have version 2.3.1.138 (hardware: rev C-5)
The following is my motion lighting:
The current mode: Night
The following is the error log:
app:9562022-04-13 21:01:34.606 error java.lang.NullPointerException: Cannot invoke method size() on null object on line 1111 (method motionActive)
app:9562022-04-13 21:01:34.584 info Motion active: Study Motion Sensor```
In case you haven’t seen the solution in the other thread, you just need to recreate the ML rule to fix this. There was a breaking change in the last update.
Thanks; I wasn't not realise that there was a follow-up discussion on the other thread.
That's bad that we need to create the ML rule, the fact this was caused by the untested patch to begin with.
