I am re-writing a rule that turns on my bathroom heat on weekday mornings. It is now in legacy and I am moving to rule 5.1. I wanted to use a wait for event at a certain variable time. I initially created a local date/time variable but when I opened the wait for event it wasn't available, which I then remembered reading, that you couldn't do events with local variables.
I happen to have one hub date/time variable available on this hub so I was able to select that then delete the line. There was no option to cancel. I wonder what would have happened if I had no variable to select. I guess my only option would be to hit the back button, which I know is frowned upon. Not a huge issue but something to maybe add a way to exit.
