Just installed 2.2.9.129. Dashboards fail to load on HTTPS mode.
Browser blocks because mixed HTTP/HTTPS modes:
Blocked loading mixed active content “http://[IP]]/apps/api/1/dashboard/13?access_token=[[ID]]”
Dashboards still work on HTTP, though, that really shouldn't be used, ideally.
Not fixed in 2.2.9.130. Bummer.
When accessing the hub from HTTPS, the dashboards are still trying to launch as HTTP.
Specificaly this. Can you fix this?
File: https://HUBITAT-IP/ui2/dashboard2/menu/js/app.js
methods: {
openDashboard: function (t) {
"threedot" != t.target.className &&
(this.isLocal
? (window.location = "http://" + localIp + "/apps/api/" + appId + "/dashboard/" + this.dashboard.id + "?access_token=" + access_token)
: (window.location = "https://cloud.hubitat.com/api/" + hubId + "/apps/" + appId + "/dashboard/" + this.dashboard.id + "?access_token=" + access_token));
On the window.location for the openDashboard method, change the protocol to match the browser protocol (or just HTTPS because we should all be using HTTPS.)
How does it look in 2.2.9.131?
Installed 2.2.9.134 and can confirm fixed.
Thank you!
Cavy
April 23, 2023, 5:25am
6
Sorry to raise this one again, esp if there's a newer post.
Appears to still be an issue in 2.3.5.125 around line 347.
In file /ui2/dashboard2/menu/js/app.js
menuURL:function() {
var t = "";
return source = this.isLocal?"local":"cloud",t = this.isLocal?"http://"+localIp+"/apps/api/"+appId+"/menu?access_token = "+access_token:"https://cloud.hubitat.com/api/"+hubId+"/apps/"+appId+"/menu?access_token = "+access_token,t
