Here's the rule:
I'm getting an NPE:
Also, in another RM5 rule, I noticed the "info" log entry for the app isn't showing the "set to" value for the "set variable" command:
Here's the rule:
I'm getting an NPE:
So, it appears the rule got corrupted.
I tried recreating that "IF condition" after the "at 2" that failed before (swapping the OFF and <=20 tests) by inserting a new condition before the other one.
The NPE shifted slightly it seems, as you can see in the updated rule:
That led me to think something was corrupted in the rule that I couldn't see. Here's some App State info:
SO--I created a totally new rule from scratch and it works fine.
When I was editing this bad rule, at first I didn't have the separate "OR if OFF" check for that dimmer switch and that kept in from working as desired (to me). So, I added a new "IF" condition that had the "if OFF or Dimmer<=20" conditions....then removed the original "IF Dimmer<" condition.
I also had to add some simple conditions to set the saved state variable to 0 if off, etc.
As I was shuffling the conditions around, suddenly, I had TWO of the "Simple Conditions" where the "Set Variable = Master Bathroom Lights level" became "broken rule" and the initial "Cancel Rule Timers" ALSO became a broken rule (3-4 did this).
I had no idea what corrupted them--but I recreated the desired lines and deleted the broken ones.
Apparently, that left sometime "in between" the "at 2" and "at 3" lines that was causing the NPE.
Sorry I don't recall more specifically the exact order of operations I went thru that busted all the rules. But, I figured I'd mention it so you could at least know something went awry when I was editing nested "IF/THEN/ELSE" statements.
