I have an Honeywell Z-Wave T6 pro. For a long time now the drivers have not been reporting status, now lately it no longer seems to be able to control it.
I originally was using the Advanced driver then at Hubitat's recommendation I moved to the "Generic Z-Wave Plus" driver with little to no success.
Currently the "coolingSetpoint" doesn't respond unless one uses the Refresh. And then it seems to wait for some time. Easily more that 30 seconds but it appears to be much longer.
Today the thermostat did not respond to a temperature set change. In the past I could tell the set change was immediately received by the thermostat because when I dropped the temperature I could immediately hear the compressor turn on.
I listed the current Hub firmware but this has been happening for quite some time. The last time I posted this issue several other folks chimed in as having the same problem.
Is there something I can do? I'll willingly test some beta is it would help.
John
BTW I think the heatingSetpoint is -2.0 because when I setup the thermostat I selected "no heat" in the thermostat setup menu".
