I am seeing an issue with the Generic Component Dimmer driver.
If I put in a level and duration, it says "null" for the level in the logs. Probably just cosmetic, but I thought I would report it anyway.
I input this:
The log shows this:
I input this:
The log shows this:
Generic components call “componentMethodName” example setLevel from component driver would call “componentSetLevel” can you put a debug log on componentSetLevel?
I see a logging error on the componentDimmer.. fixing.. This is a logging error and should have still called componentSetLevel with the proper values..
Yeah, I made sure the log in question was coming from the component driver and not the parent 1st.
Seemed only cosmetic when I looked yesterday.
Thanks @bcopeland .
