I didnāt write the built-in.. It was here before me
Yep, sorry to say it is your driver. I reverted back to your driver to see if the problem was still there.
I'm glad I'm using Farenheit! I didn't notice a problem with the driver, and I really like using Bryan's because the built-in one doesn't allow auto for my thermostats for some reason. At least it didn't before.
I have multiple sonoff temperature sensors, and just niticed this morning that the sensors report 100% humidity on my dashboard.
When I check the sensor it self in the device invetory, it states the correct % (72% when I checked).
Enyone else having this issue?
Couldnāt agree more. Never hurts to remember that this hub and most devices that connect to it are in a market segment that simply isnāt intended for truly mission critical applications. Even settings like healthcare or other high-stakes industries have to account for failure points, but they generally dedicate a lot more time, money, expertise, maintenance etc. that isnāt feasible for most home users.
And since Hubitat doesnāt force firmware updates on us, no reason to hit the upgrade button at the first possible opportunity unless the update addresses a problem one is having.
Donāt forget itās possible to downgrade and restore a backup if it turns out a firmware upgrade does cause new problems for a particular userās setup.
Sure, as long as your backup is in phase with the backup (eg. SA 1.1)
Sorry Iām not sure what you mean?
Simple Automation 1.1 is new for 2.2.4. It will not work with 2.2.3. And, it hasn't been treating me that well, but that's an aside.
Oh I see, I think.
Yes, if you want to downgrade firmware versions, youāll also need a backup of the hub database from the prior firmware version.
Since the hub keeps a limited number of backups available on the hub itself, that may require taking manual backups and downloading to a PC.
Just prior to performing a firmware upgrade is usually a good opportunity to do so. There are also ways to automate downloading of hub backups to another device on oneās LAN.
Do you have any recommendations on these?
Several threads have discussed in the past, here are some. I canāt speak from personal experience with any method other than using a NodeRed flow (mentioned in the third linked thread below).
