I have a number of "old" Leviton plug in dimmers Model VRPD3-1LW .
I found the ported Smartthings driver works best for me:
* https://github.com/SmartThingsCommunity/SmartThingsPublic/tree/ master/devicetypes/smartthings/zwave-dimmer-switch-generic.src
* originally was SmartThings "switch - dimmer" driver.
* 2018-12-09 - in process of converting to Hubitat for WD500Z-1 dimmers (never completed)
* 2019-01-18 - Installed to work the Leviton Dimmer Modules VRPD3
* Copyright 2015 SmartThings
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
metadata {
definition(name: "Z-Wave Dimmer Switch Generic (Leviton)", namespace: "smartthings", author: "SmartThings") {
capability "Switch Level"
capability "Actuator"
capability "Health Check"
capability "Switch"
capability "Polling"
capability "Refresh"
capability "Sensor"
capability "Light"
fingerprint inClusters: "0x26", deviceJoinName: "Z-Wave Dimmer"
fingerprint mfr: "001D", prod: "1902", deviceJoinName: "Z-Wave Dimmer"
fingerprint mfr: "001D", prod: "3301", model: "0001", deviceJoinName: "Leviton Dimmer Switch"
fingerprint mfr: "001D", prod: "3201", model: "0001", deviceJoinName: "Leviton Dimmer Switch"
fingerprint mfr: "001D", prod: "1B03", model: "0334", deviceJoinName: "Leviton Universal Dimmer" // this matches our Leviton
fingerprint mfr: "001D", prod: "1001", model: "0334", deviceJoinName: "Leviton 3-Speed Fan Controller"
fingerprint mfr: "001D", prod: "0602", model: "0334", deviceJoinName: "Leviton Magnetic Low Voltage Dimmer"
fingerprint mfr: "001D", prod: "0401", model: "0334", deviceJoinName: "Leviton 600W Incandescent Dimmer"
fingerprint mfr: "0039", prod: "5044", model: "3033", deviceJoinName: "Honeywell Z-Wave Plug-in Dimmer (Dual Outlet)"
fingerprint mfr: "0039", prod: "5044", model: "3038", deviceJoinName: "Honeywell Z-Wave Plug-in Dimmer"
fingerprint mfr: "0039", prod: "4944", model: "3038", deviceJoinName: "Honeywell Z-Wave In-Wall Smart Dimmer"
fingerprint mfr: "0039", prod: "4944", model: "3130", deviceJoinName: "Honeywell Z-Wave In-Wall Smart Toggle Dimmer"
fingerprint mfr: "0063", prod: "4944", model: "3034", deviceJoinName: "GE In-Wall Smart Fan Control"
fingerprint mfr: "0063", prod: "4944", model: "3131", deviceJoinName: "GE In-Wall Smart Fan Control"
fingerprint mfr: "0039", prod: "4944", model: "3131", deviceJoinName: "Honeywell Z-Wave Plus In-Wall Fan Speed Control"
//fingerprint mfr: "014F", prod: "5744", model: "3530", deviceJoinName: "Linear In-Wall Dimmer"
} // --- end of definition ---
} // --- end of metadata ---s
WD500Z-1
deviceType: 17495
inClusters: 0x26,0x2B,0x2C,0x27,0x73,0x70,0x86,0x72
deviceId: 12340
manufacturer: 335 (0x014F)
Z-Wave Product ID: 0x3034 <--- fingerprint seems to be : low byte, hi byte
Z-Wave Product Type: 0x4457
def installed() {
// Device-Watch simply pings if no device events received for 32min (checkInterval)
sendEvent(name: "checkInterval", value: 2 * 15 * 60 + 2 * 60, displayed: false, data: [protocol: "zwave", hubHardwareId: device.hub.hardwareID, offlinePingable: "1"])
def commands = refresh()
if (zwaveInfo?.mfr?.equals("001A")) {
commands << "delay 100"
//for Eaton dimmers parameter 7 is ramp time. We set it to 1s for devices to work correctly with local execution
commands << zwave.configurationV1.configurationSet( configurationValue: [1], parameterNumber: 7, size: 1).format()
} else if (isHoneywellDimmer()) {
//Set ramp time to 1s for this device to turn off dimmer correctly when current level is over 66.
//Parameter 7 - z-wave ramp up/down step size, Parameter 8 - z-wave step interval equals configurationValue times 10 ms
commands << "delay 200"
commands << zwave.configurationV1.configurationSet( configurationValue: [0, 1], parameterNumber: 8, size: 2).format()
//Parameter 7 - manual operation ramp up/down step size, Parameter 8 - z-wave manual operation interval equals configurationValue times 10 ms
commands << zwave.configurationV1.configurationSet( configurationValue: [1], parameterNumber: 9, size: 1).format()
commands << zwave.configurationV1.configurationSet( configurationValue: [0, 1], parameterNumber: 10, size: 2).format()
response(commands)
def updated() {
def getCommandClassVersions() {
0x20: 1, // Basic
0x26: 1, // SwitchMultilevel
0x56: 1, // Crc16Encap
def result = null
if (description != "updated") {
//log.debug "parse() >> zwave.parse($description)"
def cmd = zwave.parse(description, commandClassVersions)
if (cmd) {
result = zwaveEvent(cmd)
return result
def zwaveEvent(hubitat.zwave.commands.basicv1.BasicReport cmd) {
dimmerEvents(cmd)
def zwaveEvent(hubitat.zwave.commands.basicv1.BasicSet cmd) {
dimmerEvents(cmd)
def zwaveEvent( hubitat.zwave.commands.switchmultilevelv1.SwitchMultilevelReport cmd) {
dimmerEvents(cmd)
def zwaveEvent( hubitat.zwave.commands.switchmultilevelv1.SwitchMultilevelSet cmd) {
dimmerEvents(cmd)
private dimmerEvents(hubitat.zwave.Command cmd) {
def value = (cmd.value ? "on" : "off")
def result = [createEvent(name: "switch", value: value)]
if (cmd.value && cmd.value <= 100) {
result << createEvent(name: "level", value: cmd.value == 99 ? 100 : cmd.value)
return result
def zwaveEvent(hubitat.zwave.commands.hailv1.Hail cmd) {
createEvent([name: "hail", value: "hail", descriptionText: "Switch button was pressed", displayed: false])
def zwaveEvent(hubitat.zwave.commands.manufacturerspecificv2.Manufa cturerSpecificReport cmd) {
log.debug "manufacturerId: $cmd.manufacturerId"
log.debug "manufacturerName: $cmd.manufacturerName"
log.debug "productId: $cmd.productId"
log.debug "productTypeId: $cmd.productTypeId"
def msr = String.format("%04X-%04X-%04X", cmd.manufacturerId, cmd.productTypeId, cmd.productId)
updateDataValue("MSR", msr)
updateDataValue("manufacturer", cmd.manufacturerName)
createEvent([descriptionText: "$device.displayName MSR: $msr", isStateChange: false])
def zwaveEvent(hubitat.zwave.commands.switchmultilevelv1.SwitchMult ilevelStopLevelChange cmd) {
[createEvent(name: "switch", value: "on"), response( zwave.switchMultilevelV1.switchMultilevelGet().format())]
def zwaveEvent(hubitat.zwave.commands.crc16encapv1.Crc16Encap cmd) {
def versions = commandClassVersions
def version = versions[cmd.commandClass as Integer]
def ccObj = version ? zwave.commandClass(cmd.commandClass, version) : zwave.commandClass(cmd.commandClass)
def encapsulatedCommand = ccObj?.command(cmd.command)?.parse( cmd.data)
if (encapsulatedCommand) {
zwaveEvent(encapsulatedCommand)
def zwaveEvent(hubitat.zwave.Command cmd) {
// Handles all Z-Wave commands we aren't interested in
def on() {
delayBetween([
zwave.basicV1.basicSet(value: 0xFF).format(),
], 5000)
def off() {
delayBetween([
zwave.basicV1.basicSet(value: 0x00).format(),
], 5000)
def setLevel(value) {
log.debug "setLevel >> value: $value"
def valueaux = value as Integer
def level = Math.max(Math.min(valueaux, 99), 0)
if (level > 0) {
sendEvent(name: "switch", value: "on")
} else {
sendEvent(name: "switch", value: "off")
delayBetween([zwave.basicV1.basicSet(value: level).format(), zwave.switchMultilevelV1.switchMultilevelGet().format()], 5000)
def setLevel(value, duration) {
log.debug "setLevel >> value: $value, duration: $duration"
def dimmingDuration = duration < 128 ? duration : 128 + Math.round(duration / 60)
def getStatusDelay = duration < 128 ? (duration * 1000) + 2000 : (Math.round(duration / 60) * 60 * 1000) + 2000
delayBetween([zwave.switchMultilevelV2.switchMultilevelSet( value: level, dimmingDuration: dimmingDuration).format(),
zwave.switchMultilevelV1.switchMultilevelGet().fo rmat()], getStatusDelay)
def poll() {
refresh()
* PING is used by Device-Watch in attempt to reach the Device
def ping() {
refresh()
def refresh() {
log.debug "refresh() is called"
def commands = []
commands << zwave.switchMultilevelV1.switchMultilevelGet().format()
if (getDataValue("MSR") == null) {
commands << zwave.manufacturerSpecificV1.manufacturerSpecif icGet().format()
delayBetween(commands, 100)
// --- eof ---
def isHoneywellDimmer() {
zwaveInfo?.mfr?.equals("0039") && (
(zwaveInfo?.prod?.equals("5044") && zwaveInfo?.model?.equals("3033")) ||
(zwaveInfo?.prod?.equals("5044") && zwaveInfo?.model?.equals("3038")) ||
(zwaveInfo?.prod?.equals("4944") && zwaveInfo?.model?.equals("3038")) ||
(zwaveInfo?.prod?.equals("4944") && zwaveInfo?.model?.equals("3130"))
Get Command Class Report:
dev:9712018-12-09 08:37:53.919 pm infoCommandClassReport- class:0x72, version:1
dev:9712018-12-09 08:37:53.419 pm infoCommandClassReport- class:0x86, version:1
dev:9712018-12-09 08:37:52.915 pm infoCommandClassReport- class:0x70, version:1
dev:9712018-12-09 08:37:52.415 pm infoCommandClassReport- class:0x73, version:1
dev:9712018-12-09 08:37:51.914 pm infoCommandClassReport- class:0x27, version:1
dev:9712018-12-09 08:37:51.411 pm infoCommandClassReport- class:0x2C, version:2
dev:9712018-12-09 08:37:51.030 pm infoCommandClassReport- class:0x2B, version:1
dev:9712018-12-09 08:37:50.462 pm infoCommandClassReport- class:0x26, version:1
