I've got a couple RM 5.1 rules that don't seem to be working properly, so I created a test case.
One issue demonstrated here shows that pasting a "copied" "wait for event-elapsed time=2sec" into an existing "Repeat" loop causes the "Stop Repeating Actions" to be ignored.
Here is the log:
Here is the rule:
Any time the "Var1=2, Var2=1 True" message is logged, the "Stop Repeating Actions" should trigger--so it shouldn't be repeated twice.
Prior to inserting that "Wait", it behaved properly:
(Note that I also added the "after repeat" wording to that log message and added the "Starting" log message between these tests).
In two other rules that are of a similar form (and which are logically almost identical), I am seeing the final "Else" running even though a preceding "Else-If" ran. I've not been able to reproduce this yet.
But, I suspect it had to do with copy/pasting some of the If/Then/Else and/or repeat logic.
