I'm noticing two bugs with the habitat mobile application for Android. I'm not sure if it's the mobile application or the hub itself. I'm on hub 2.4.2.152.
- When I click on the geofence wheel/gear it just tells me I tapped the item and does not actually open up the settings.
- The other issue is I cannot open up the old style dashboards remotely. However, the easy dashboards will open remotely off network. I know this did work previously prior to updating the hub. However, I don't know if it's a hub or a mobile app issue. The dashboard does work locally and through remote admin.
I'm using a pixel 8 pro with the latest Android OS.
Like to see if anyone sees this as well. Thank you for your help.
