[2.0.4] Schlage FE599 Not Reporting Keypad Events
The Generic Z-Wave Lock driver is still not reporting lock events generated by the keypad after the 2.0.4 update.
Event Log:
[dev:361](http://192.168.X.X/logs#dev361)2019-01-12 02:59:22.193 pm [warn](http://192.168.X.X/device/edit/361)skipped zAlarmType:0, zAlarmEvent:0, alarmType:16]
[dev:361](http://192.168.X.X/logs#dev361)2019-01-12 02:59:22.192 pm [debug](http://192.168.X.X/device/edit/361)alarmv2.AlarmReport: AlarmReport(alarmLevel:1, alarmType:16, eventParameter:[], numberOfEventParameters:0, zensorNetSourceNodeId:0, zwaveAlarmEvent:0, zwaveAlarmStatus:0, zwaveAlarmType:0)
[dev:361](http://192.168.X.X/logs#dev361)2019-01-12 02:59:22.187 pm [debug](http://192.168.X.X/device/edit/361)parse: zw device: 4C, command: 9881, payload: 00 71 05 10 01
Using a ported/modified Z-Wave Lock driver from SmartThings I can get the lock to report lock/unlock events generated by the keypad. I just cannot get code get/set to work due to the undocumented way HE implements codes. The lock will correctly report which slot was used.
[dev:361](http://192.168.X.X/logs#dev361)2019-01-12 03:00:39.618 pm [debug](http://192.168.X.X/device/edit/361)[DTH] zwaveEvent(hubitat.zwave.commands.alarmv2.AlarmReport) returning with result = [[name:lock, value:unlocked, isStateChange:true, descriptionText:Unlocked by "{code=????, name=Steve}", data:[codeId:1, usedCode:1, codeName:{code=????, name=Steve}, method:keypad, lockName:Lock, Kitchen Door]]]
[dev:361](http://192.168.X.X/logs#dev361)2019-01-12 03:00:39.599 pm [trace](http://192.168.X.X/device/edit/361)[DTH] Executing 'handleAlarmReportUsingAlarmType' with cmd = AlarmReport(alarmLevel:1, alarmType:16, eventParameter:[], numberOfEventParameters:0, zensorNetSourceNodeId:0, zwaveAlarmEvent:0, zwaveAlarmStatus:0, zwaveAlarmType:0)
Hope this can get fixed. Thanks!
The virtual lock driver code is published in our public github repo.
What about the code for the Generic Z-Wave Lock? It would require considerably less time to add code to parse the missing alarm report than to rewrite the codes portion of the SmartThings driver
There's still a bug in that section of the code (apparently) for the FE599
The alarm report isn’t being parsed at all, the logs indicate it's "skipping unhandled event type".
If you look at the ST driver, the event follows this flow:
  1. Parse() calls zwaveEvent(hubitat.zwave.commands.alarmv2.AlarmReport cmd)
  2. zwaveEvent(hubitat.zwave.commands.alarmv2.AlarmReport cmd) calls handleAlarmReportUsingAlarmType(cmd) (default in the if/else block)
  3. handleAlarmReportUsingAlarmType(cmd) matches alarmType==16
     	case 16: // Note: for levers this means it's unlocked, for non-motorized deadbolt, it's just unsecured and might not get unlocked
     	case 19: // Unlocked with keypad
     		map = [ name: "lock", value: "unlocked" ]
     		if (cmd.alarmLevel != null) {
     			codeID = readCodeSlotId(cmd)
     			codeName = getCodeName(lockCodes, codeID)
     			map.isStateChange = true // Non motorized locks, mark state changed since it can be unlocked multiple times
     			map.descriptionText = "Unlocked by \"$codeName\""
     			map.data = [ codeId: codeID as String, usedCode: codeID, codeName: codeName, method: "keypad" ]
     		break
And the rest is history as we know it.
Yeah, I know what it's missing, and I added the code in build 2.0.4 to capture it, obviously that's worked out well, which is why i despise modifying drivers without having the device on hand, I'll look at it some more soon.
I am certainly willing to help you Test since I have got several of these. Please let me know how I can assist
Unfortunately lock user code reporting broke for me too -- I think it was 2.0.4 also. It was working up until a few days ago. I have both a yale lock and a kwikset lock -- both stopped reporting unlock events with keypad code. Both are using the Generic Z-Wave Lock and I see the same "skipped zAlarmType" lines as srwhite.
I have one lock on an outside door that unlocks the inside one too when unlocked with my code. One of the main reasons I got Hubitat -- it reduced the dealy between unlocking one door and the other door from 20+ seconds (sometimes 1 min) on Smarthings down to 3 sec or less on Hubitat!
Hoping it can get fixed soon!
Will be sorted out in the next release.
Thank you.
Just an FYI, my Kwikset 914 isn't reporting lock codes any more either.
Last one was on 1/10, and it has been unlocked with code many times since then.
Looking at the events, it seemed to work fine before then... I've installed all the updates. Was there one on 1/10 perchance?
Edit... Last time it reported correctly was on 2.0.3... hasn't reported code use once in 2.0.4...
Was definitely annoying when the maid lock code didn't turn off the alarm today (via an RM rule I have built)...
Any word on if lock codes for makes other than Schlage will be fixed soon? I miss my uinlock lock code events... @mike.maxwell
Can this be fixed via a hotfix instead of waiting for a new release @mike.maxwell ? Or is there a trick to roll back to 2.0.3? I tried to roll back but I couldn't go that far back, only to previous 2.0.4 biulds.
If you are referring to the FE599 it has not reported code usage on any build so far. It’s just a waiting game at this point.
I get the exact same "skipped zAlarmType" message when unlocking my Kwikset locks with the keypad.
This is frustrating, as I have RM logic based on lock codes. Obviously all that has been broken since 2.0.4 was installed.
@mike.maxwell When will this get fixed? Can you just do a hotfix and put it back to the 2.0.3 functionality if it is going to be a while? You guys broke my automations that worked fine before, that seems like something that shouldn't have to wait for another release to me.
This is another case where if you posted your built-in driver code, I could have fixed/reverted it myself... But in absence of that, we need to rely on timely fixes from the Hubitat team.
This gets my vote too.
This I completely agree with. I realize things change quickly with the rapid updates, but it would be nice to at least have the “Generic” line of drivers published.
I'll bring this up in engineering.
I'm glad I found this thread. I submitted a support ticket Wed 1/16 but haven't heard back from anyone. I did get the automated reply which doesn't include a ticket number so I can't reference it here.
I'm having the same issue with my Kwikset 914 z-wave lock. I get reports of lock/unlock but it's not sending keypad unlock data (codes used, etc).
  • deviceType: 1
  • zwaveSecurePairingComplete: true
  • inClusters: 0x72,0x86,0x98
  • deviceId: 1
  • manufacturer: 144
I am also seeing "skipped" messages around the time that I unlock with the keypad:
warn skipped zAlarmType:0, zAlarmEvent:0, alarmType:19]
Yup. That's what I see on all 3 of my Kwikset locks since installing 2.0.4. I REALLY hope they fix this soon - has already been 11 days...
Schlage * 3 not notifying on lock code either. New to Hubitat and lock codes across more than one is cumbersome, Is there a third-party equivalent like RBoy on ST?
I don't want to revert my locks back to ST, but if this is what HE has for locks, I will.
