The ReadMe pretty much explains the remaining steps, regarding simply copying the contents of the libraries and sketches folders in the zip file to your corresponding folders.
Thanks. I must not have had something in the correct directory before. Now I got as far as test compiling one of your sample sketches which is further than I got before. I'll start attempting the next steps when I have more mental energy.
After a few struggles, I got Hubduino working to the point that I can control an LED on the Arduino from a Hubitat dashboard. I can also send info the other way with a physical button on the Arduino working as a contact sensor in Hubitat. Then, it got late and I needed sleep so I could function today in the job that I actually get paid to do. I am looking forward to building the Arduino circuit you provided and testing that. It feels like I am close to accomplishing my original goal. (I've felt that way before and found more barriers.)
I showed my wife how I could light the LED from a Hubitat dashboard. She was not nearly as impressed as I thought she should be.
I completely understand what you're saying... I get the same reaction from my family. If they only knew how much work it took to get a little LED light to turn on...
Which driver should I be using? I'm thinking contact sensor, but would like to confirm.
How much AC current is needed? Your post above says:
Your picture shows 24.2 kOhms with 24VAC. Wouldn't that yield 1 ma instead of 10 ma?
I haven't made this work yet, but I don't know whether or not my issue is with this part of the circuit. My push button, which was previously working as a contact sensor, is no longer working either. I changed the power supply to the NodeMCU from a USB cable to a 9V battery via the power supply circuit that came with an Arduino kit. That appears to work, but it is a suspect since it is something that changed between the time it worked and the time that it doesn't. Is Hubduino pretty good about re-connecting to Hubitat after the Arduino has been unpowered for a few days?
Yes. I believe I was just trying to keep the current seen by the H11AA1 to under 10ma, which is what it is rated for. The 1 ma seems to work fine to trigger the H11AA1.
Yes, it should connect and just start working immediately.
Is there a reason to power the NodeMCU board with a 9v battery?
The 9V battery lets me carry it from the table where I work on it to the furnace room to test it. In the location I intend to use the circuit once it is working, it is not convenient to power it with a USB. My preference would be to power it with the 24VAC that is right there.
Is the whole home losing power? Or just unplugging the HubDuino Microcontroller?
I have an Arduino MEGA 2560 + W5500 Ethernet shield that have been running for years through many power blips. I also have a NodeMCU ESP8266 board that also always recovers itself after a power blip.
I just unplugged in for about a minute. The cord was dangling, so I needed to re-arrange it so the plug wasn't supporting weight. It was working properly before I unplugged it, but didn't resume working when I plugged it back in. I tried pressing the reset button, but that didn't solve it.
