did something change in that last version of firmware that periodically restarts the zigbee network? noticed this in my logs on my C8 a bit ago. I'm going to shut down and power cycle it just in case its not.
You might be seeing this?
Did you migrate to the C8 or start fresh with it? If you migrated, make sure to send a message to Support. I've had the same issue since I migrated from a C5 on Saturday. See: [INCIDENT] Zigbee issues following migration from an older hub
sent in my message last night, thanks. Just a FYI the shutdown and power cycle didn't clear it up. I'm starting to consider moving back to my C5,
