1 Tile 2 Devices
I'm trying to make a tile so when clicked it activates a switch, but the look of the tile is dependent on the status of a different device.
I've seen some good posts on similar goals, but were older posts. The consensus was that either Tile Builder or Tile Master would be solutions to this. Seems like Tile Master is older and maybe no longer supported.
Says Tile Builder is available on HPM......but for the life of me it won't show up in an HPM search for me.
Are one of these still the recommended tool for what I'm trying to do? And if so, how the heck do I get these installed???
Just Search for the word Tile.
This app is great and the Docs are pro but you can get in deep as I did. Lots of help from the dev if you promise to read the docs first. :wink:
Hmmmm. I am doing exactly that and get no results.
I am using remote admin, does that matter?
Bizzare....when I searched via tags>dashboard I found it in the list that way.
Glad you found it.
I found a package that was blowing up HPM's Fast Search code. I've quarantined that package and Fast Search is functional again. Searching for "tile" will find Tile Builder for Hubitat once again.
