had to lash up a driver for wifi presence, very disappointed the mobile app has prefomed very well for me over the years
* Hubitat presence Ping
* Licensed Virtual the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
* Change History:
* Date Who What
2021-11-05 thebearmay Add Text Logging option
2022-01-03 mark-c-uk striped down to work as presance sensor
metadata {
definition (
name: "Hubitat presence Ping",
namespace: "mark-c-uk",
author: "mark-c-uk",
importUrl:"",
singleThreaded: true
capability "Actuator"
capability "Configuration"
capability "PresenceSensor"
capability "Initialize"
attribute "pingData", "string"
preferences {
input("ipAdd", "string", title: "IP address of device", required:true, submitOnChange: true)
input("ipAddRout", "string", title: "IP address of router, to test befor sending away", submitOnChange: true)
input("numPings", "number", title: "Number of pings to issue", defaultValue:3, required:true, submitOnChange:true, range: "1..5")
input("pingPeriod", "number", title: "Ping Repeat in Seconds\n Zero to disable", defaultValue: 0, required:true, submitOnChange: true)
input("awayPeriod", "number", title: "number of missed pings to be away", defaultValue: 5, required:true, submitOnChange: true)
input("debugEnable", "bool", title: "Enable debug logging?")
input("textLoggingEnabled", "bool", title: "Enable Text Logging", defaultValue:false)
input "sendPushMessageto", "capability.notification", title: "Send a Push notification to?", multiple: true, required: false
def installed() {
log.trace "installed()"
def configure() {
unschedule()
if (state.away == null) state.away = 0
log.debug "configure()"
updateAttr("pingData"," ")
if (device.currentValue("presence") == null) updateAttr("presence","not present")
updated()
def initialize(){
configure()
def updated(){
log.trace "updated()"
if (ipAdd == null){
log.warn "no ip address"
updateAttr("pingData", "no Device IP address")
state.validIP = false
else if (validIP(ipAdd) == true){
if(debugEnable == true) log.debug "Device IP address format valid"
updateAttr("pingData", "Device IP address format valid")
state.validIP = true
else{
log.warn "Device IP address format invalid"
updateAttr("pingData", "Device IP address format invalid")
if (ipAddRout == null){
log.warn "no ip addressvfor router"
state.router = false
else if (validIP(ipAddRout) == true){
if(debugEnable == true) log.debug "router IP address format valid"
state.router = true
else{
log.warn "router IP address format invalid"
if(debugEnable == true) runIn(1800,logsOff)
if (numPings == null) numPings = 3
if (awayPeriod == null) awayPeriod = 5
if(state.validIP == true) pinger()
def refresh() {
unschedule(refresh)
def updateAttr(aKey, aValue){
sendEvent(name:aKey, value:aValue)
def pinger(){
if (settings.textLoggingEnabled == true) log.debug "Ping initiated"
if (state.responseReady == false){
log.warn "not ready"
if(pingPeriod > 0) runIn(pingPeriod, "pinger")
return
if (sendPing(settings.ipAdd) < 100){
if (state.away != 0) state.away = 0
if(settings.textLoggingEnabled == true) log.debug "Presence 'present' for $ipAdd"
updateAttr("presence","present")
else {
if (device.currentValue("presence") == "not present"){
if(settings.textLoggingEnabled == true) log.debug "Presence not present already $ipAdd, ${state.away} number of times"
else{
state.away += 1
if(settings.textLoggingEnabled == true) log.debug "Presence not presentfor $ipAdd , NP ${state.away}"
if (state.away > awayPeriod){
if (state.router == true){
if (sendPing(ipAddRout) < 100){
if(settings.textLoggingEnabled == true) log.debug "Presence set to 'not present' for $ipAdd"
else {
updateAttr("pingData","router not present")
} //end use router option
else {
if(settings.textLoggingEnabled == true) log.debug "not present' for $ipAdd, ${state.away} number of times"
if(settings.pingPeriod > 0) runIn(settings.pingPeriod, "pinger")
if(settings.textLoggingEnabled == true && settings.pingPeriod > 0) log.debug "Next ping in $pingPeriod seconds"
def sendPing(ipAddress){
if(textLoggingEnabled == true) log.debug "Hub internal ping method selected"
state.responseReady = false
hubitat.helper.NetworkUtils.PingData pingData = hubitat.helper.NetworkUtils.ping(ipAddress, numPings.toInteger())
int pTran = pingData.packetsTransmitted.toInteger()
if (pTran == 0){ // 2.2.7.121 bug returns all zeroes on not found
pingData.packetsTransmitted = numPings
pingData.packetLoss = 100
String pingStats = "Transmitted: ${pingData.packetsTransmitted}, Received: ${pingData.packetsReceived}, %Lost: ${pingData.packetLoss}"
if(textLoggingEnabled == true) log.debug "Ping Stats for $ipAddress: $pingStats"
//updateAttr("pingData", "$ipAddress: $pingStats")
state.responseReady = true
return pingData.packetLoss
//if (sendPushMessageto != null){
// sendPushMessageto.deviceNotification("some error" )
def validIP(ipAddress){
regxPattern =/^((25[0-5]|2[0-4][0-9]|[01]?[0-9][0-9]?)\.){3}(25[0-5]|2[0-4][0-9]|[01]?[0-9][0-9]?)$/
boolean match = ipAddress ==~ regxPattern
return match
void logsOff(){
device.updateSetting("debugEnable",[value:"false",type:"bool"])
