Continuing the discussion from Hub Update 1.1.7:
I'm curious ![]()
I'm curious ![]()
Someone reported the event and log text for a few specific physical actions were incorrect.
tsk tsk... meticulous users you have ! xD
@mike.maxwell it seems they are still not matching:
(btw.. does "physical" mean manually activated?)
| Name | Value | Unit | Description Text | Source | Type | Date |
| lock | locked | door was manually locked [physical] | DEVICE | 2018-11-07 06:21:09.399 PM PST | ||
| lock | unlocked | door was unlocked by foobar | DEVICE | physical | 2018-11-07 06:20:01.706 PM PST | |
| lock | locked | door was locked via keypad | DEVICE | physical | 2018-11-07 05:49:25.719 PM PST | |
| lock | unlocked | door was manually unlocked [physical] | DEVICE | 2018-11-07 05:48:49.919 PM PST | ||
| lock | locked | door is locked | DEVICE | 2018-11-07 05:48:44.631 PM PST |
Not sure what you mean by not matching, are you referring to the type column not matching the description?, or something else.
yes, the type column not matching the text in the description
I will throw my 2 cents out there!
Looks like the first 4 events were physical, first/fourth done by physically turning the lock and second/third done by keypad. I too am stumped by how the fifth event was done, was it done at the keypad or by the hub?
It might help to take [physical] off the description text and move to the type, to be consistent.
@denise.grider that's correct. IIRC, the fifth one is by zwave command.
