I tried to port this over and configure based on the new buttonpushed thing, but it’s not a simple replace I guess.
Anyone else have any luck with these?
Did u also replace instances of physicalgraph with hubitat?
Yeah, that part I got down…it’s all the complicated bits…
Any luck with this?
I gave up on it. I was only able to get one of my two to join. Hubitat won’t even see the second one after multiple exclusion/defaults.
These are a very lightly used device in my house so it’s not been a priority.
Yeah, me too. I bought one a while ago, cannot remember the last time I used it to be honest. I think I’ll end up with a couple devices like this, that just might not have the audience to have the drives updated. Would not really be a big deal to me.
I just reread this. Sonyou did get one to pair? Did it work? Some? Fully? Not at all? If so would you mind sharing any driver updates?
Hate to bump this thread so much later—I'm wondering if anyone else has had any luck with this driver? Otherwise, I’m going to dive into it over the weekend.
For anyone whose zwn-sc7 won’t pair... you have to factory reset it, trip the breaker, then factory reset it again. Bizarre...
No luck here. I'll try your reset process though.
Mine is working fine ( I can see in the log that it is responding to scene activation ).
What I am unsure of is how to map the individual buttons to events in the Hubitat...
How did you get yours to configure? I can handle button responses (I think). Right now, it's stuck with all 7 LEDs on, and it's not sending any events. I've only been able to work on my driver every now and then, but I've made some progress with it. Unfortunately, there's not much for documentation on these...
My primary/SIS controller is not the Hubitat, so I can control Associations/etc via that hub ( FWIW I have used a SmartThings Hub for over 2 years ( maybe three) as a secondary controller).
I haven't figured out how to have the Hubitat hub perform basic network management at this point.
I have a driver which works, but without the ability to configure the device on its own... its incomplete.
I did figure out how to make the buttons register events
To make the device work you have to associate the Hubitat hub with each of the buttons and set values for the seven scenes ( the Enerwave device doesn't provide a scene for button off, just button on, I believe ( I can't recall this off of the top of my head )).
BTW the "all lights on" means it had an error the last time a button was pressed ( it also does this when it is first installed/reset ).
Press a button, and then see if blink,s and then turns on all the buttons.
If so? An error occurred.
Anybody out there get this thing to function on Hubitat? I was able to pair, but my attempt at porting the ST DTH must not have worked.
If not, can anyone recommend an alternative? I really need one button, not necessarily all and I have a hot and neutral in the box I can use.
I've been working on mine, still. I've pushed it back for other projects, unfortunately. The Remotec 90 is what I've been using in the meantime. I plan to put some time in on it on Saturday.
Hey all. Just wanted to drop in and say that I’m selling my SC7, and won’t be working on this driver.
If staff (@chuck.schwer or @mike.maxwell ?) would like my SC7 to play with/get working before I sell it (or if they just want it) I would gladly give it up so the community could have a driver. I just don’t have time to work on this driver reliably—and I’d rather focus on getting the others work perfectly.
For anyone left wondering, I might just take a 7-button dumb Fan Controller, a couple of iris Fobs, and solder the leads to the buttons
Anyone ever get one of these to work?
Nope. I'll actually have some play-time this upcoming weekend, though. I'll let you know what I can get working
I have 5 of these installed in my house, Would love to see this happen.
I also have one of these that I would love to see working in Hubitat!!
