You mentioned reboot and shut down, did you pull power for 30 seconds so the radio will fully power off? Also how is hub being powered, see info below:
Also, since you said it works fine on ZIP, what is your actual issue with SmartStart and LR? You never said what the original problem was, just that is was a "common" problem???
