Lutron is completely different than Zwave. They are on different frequencies and are different protocols. There is almost zero possibility of a Lutron interfering with Zwave.
Sorry - Leviton zwave
Via a code on the schlage - by hand
ok so do you have both repeaters or one? if she goes to the one close to the hub and you controlt he lock from the ide will that one flash?
2 one close to the hub, other by the door with the important lock - per her neither are flashing
ok maybe it doesn't like that route. Were there any errors when you did the repair?
Can the repeater close to the hub be relocated closer or to a different outlet?
No errors - the log showed each node searching and then moving onto the next one
is there another outlet you can relocate the hub repeater to that's close? We need that light to flash. Then repair. It's all about placement.
OK, relocated the repeater, Run zwave repair - no errors (repeater is Node 13)
Removed the batteries and connected back (lock report 100% battery below)
Turned the know on and off 5 times - in the log
Repeater still does not flash.
I guess I will leave it for when I am there and start moving both repeaters around...
Turned the lock physically - looking at the debug log, all changes were registered
dev:112020-06-02 21:58:25.944 infoMain House Lock was locked by thumb turn [physical]
dev:112020-06-02 21:57:55.732 infoMain House Lock was locked by thumb turn [physical]
dev:112020-06-02 21:57:44.160 infoMain House Lock was unlocked by thumb turn [physical]
dev:112020-06-02 21:57:36.673 infoMain House Lock was locked by thumb turn [physical]
dev:112020-06-02 21:57:24.389 infoMain House Lock battery is 100%
sys:12020-06-02 21:45:25.674 infoFinished Z-Wave Network Repair
dev:652020-06-02 21:45:16.059 infoZ-Wave command:AssociationReport(groupingIdentifier: 1, maxNodesSupported: 1, reportsToFollow: 0, nodeId: [1])
sys:12020-06-02 21:45:16.050 traceZ-Wave Node 13: Repair is done.
sys:12020-06-02 21:45:16.035 traceZ-Wave Node 13: Repair is requesting node neighbor info
sys:12020-06-02 21:45:16.029 traceZ-Wave Node 13: Repair is adding return route
sys:12020-06-02 21:45:16.023 traceZ-Wave Node 13: Repair is deleting routes
sys:12020-06-02 21:45:15.972 traceZ-Wave Node 13: Repair is requesting device associations
sys:12020-06-02 21:45:11.731 traceZ-Wave Node 13: Repair is updating neighbors
sys:12020-06-02 21:45:10.699 traceZ-Wave Node 13: Repair setting SUC route
sys:12020-06-02 21:45:10.629 traceZ-Wave Node 13: Repair pinging
sys:12020-06-02 21:45:10.625 traceZ-Wave Node 13: Repair starting
sys:12020-06-02 21:45:05.616 traceZ-Wave Node 12: Repair is done.
sys:12020-06-02 21:45:05.608 traceZ-Wave Node 12: Repair is requesting node neighbor info
sys:12020-06-02 21:45:05.603 traceZ-Wave Node 12: Repair is adding return route
sys:12020-06-02 21:45:05.599 traceZ-Wave Node 12: Repair is deleting routes
sys:12020-06-02 21:45:05.591 traceZ-Wave Node 12: Repair is requesting device associations
sys:12020-06-02 21:43:31.296 traceZ-Wave Node 12: Repair is requesting node neighbor info
sys:12020-06-02 21:43:31.291 traceZ-Wave Node 12: Repair is adding return route
sys:12020-06-02 21:43:31.287 traceZ-Wave Node 12: Repair is deleting routes
sys:12020-06-02 21:43:31.283 traceZ-Wave Node 12: Repair is requesting device associations
sys:12020-06-02 21:43:31.267 traceZ-Wave Node 12: Repair is updating neighbors
sys:12020-06-02 21:43:31.251 traceZ-Wave Node 12: Repair is updating neighbors
sys:12020-06-02 21:43:31.235 traceZ-Wave Node 12: Repair is updating neighbors
sys:12020-06-02 21:43:26.174 traceZ-Wave Node 12: Repair is updating neighbors
sys:12020-06-02 21:43:25.576 traceZ-Wave Node 12: Repair setting SUC route
sys:12020-06-02 21:43:25.544 traceZ-Wave Node 12: Repair pinging
sys:12020-06-02 21:43:25.532 traceZ-Wave Node 12: Repair starting
dev:332020-06-02 21:43:20.074 debugignore: AssociationReport(groupingIdentifier: 1, maxNodesSupported: 1, reportsToFollow: 0, nodeId: [1])
sys:12020-06-02 21:43:20.063 traceZ-Wave Node 11: Repair is done.
sys:12020-06-02 21:43:20.050 traceZ-Wave Node 11: Repair is requesting node neighbor info
sys:12020-06-02 21:43:20.044 traceZ-Wave Node 11: Repair is adding return route
sys:12020-06-02 21:43:20.037 traceZ-Wave Node 11: Repair is deleting routes
sys:12020-06-02 21:43:19.977 traceZ-Wave Node 11: Repair is requesting device associations
sys:12020-06-02 21:43:16.276 traceZ-Wave Node 11: Repair is updating neighbors
sys:12020-06-02 21:43:15.534 traceZ-Wave Node 11: Repair setting SUC route
sys:12020-06-02 21:43:15.505 traceZ-Wave Node 11: Repair pinging
sys:12020-06-02 21:43:15.501 traceZ-Wave Node 11: Repair starting
dev:102020-06-02 21:43:09.978 debugskip: AssociationReport(groupingIdentifier: 1, maxNodesSupported: 5, reportsToFollow: 0, nodeId: [1])
sys:12020-06-02 21:43:09.972 traceZ-Wave Node 9: Repair is done.
dev:102020-06-02 21:43:09.968 debugparse description: zw device: 09, command: 8503, payload: 01 05 00 01 , isMulticast: false
sys:12020-06-02 21:43:09.954 traceZ-Wave Node 9: Repair is requesting node neighbor info
sys:12020-06-02 21:43:09.947 traceZ-Wave Node 9: Repair is adding return route
sys:12020-06-02 21:43:09.942 traceZ-Wave Node 9: Repair is deleting routes
sys:12020-06-02 21:43:09.890 traceZ-Wave Node 9: Repair is requesting device associations
sys:12020-06-02 21:43:06.074 traceZ-Wave Node 9: Repair is updating neighbors
sys:12020-06-02 21:43:05.506 traceZ-Wave Node 9: Repair setting SUC route
sys:12020-06-02 21:43:05.476 traceZ-Wave Node 9: Repair pinging
sys:12020-06-02 21:43:05.468 traceZ-Wave Node 9: Repair starting
dev:92020-06-02 21:42:56.699 debugskip: AssociationReport(groupingIdentifier: 1, maxNodesSupported: 5, reportsToFollow: 0, nodeId: [1])
dev:92020-06-02 21:42:56.681 debugparse description: zw device: 08, command: 8503, payload: 01 05 00 01 , isMulticast: false
sys:12020-06-02 21:42:56.656 traceZ-Wave Node 8: Repair is done.
sys:12020-06-02 21:42:56.644 traceZ-Wave Node 8: Repair is requesting node neighbor info
sys:12020-06-02 21:42:56.639 traceZ-Wave Node 8: Repair is adding return route
sys:12020-06-02 21:42:56.632 traceZ-Wave Node 8: Repair is deleting routes
sys:12020-06-02 21:42:56.492 traceZ-Wave Node 8: Repair is requesting device associations
sys:12020-06-02 21:42:51.436 traceZ-Wave Node 8: Repair is updating neighbors
sys:12020-06-02 21:42:50.508 traceZ-Wave Node 8: Repair setting SUC route
sys:12020-06-02 21:42:50.452 traceZ-Wave Node 8: Repair pinging
sys:12020-06-02 21:42:50.448 traceZ-Wave Node 8: Repair starting
sys:12020-06-02 21:39:50.341 traceZ-Wave Node 7: Repair is requesting device associations
sys:12020-06-02 21:38:20.292 traceZ-Wave Node 7: Repair is requesting device associations
sys:12020-06-02 21:36:50.237 traceZ-Wave Node 7: Repair is requesting device associations
sys:12020-06-02 21:35:20.185 traceZ-Wave Node 7: Repair is requesting device associations
dev:62020-06-02 21:34:41.308 infoADU Lock battery is 100%
dev:62020-06-02 21:34:41.306 debugBatteryReport: BatteryReport(batteryLevel:100)
dev:62020-06-02 21:34:41.282 debugparse: zw device: 06, command: 9881, payload: 00 80 03 64 , isMulticast: false
sys:12020-06-02 21:33:46.795 traceZ-Wave Node 7: Repair is requesting device associations
sys:12020-06-02 21:33:46.774 traceZ-Wave Node 7: Repair is updating neighbors
sys:12020-06-02 21:33:46.315 traceZ-Wave Node 7: Repair is updating neighbors
sys:12020-06-02 21:33:46.294 traceZ-Wave Node 7: Repair is updating neighbors
sys:12020-06-02 21:33:41.241 traceZ-Wave Node 7: Repair is updating neighbors
sys:12020-06-02 21:33:40.180 traceZ-Wave Node 7: Repair setting SUC route
sys:12020-06-02 21:33:40.127 traceZ-Wave Node 7: Repair pinging
sys:12020-06-02 21:33:40.123 traceZ-Wave Node 7: Repair starting
sys:12020-06-02 21:33:35.331 traceZ-Wave Node 5: Repair is done.
sys:12020-06-02 21:33:35.319 traceZ-Wave Node 5: Repair is requesting node neighbor info
sys:12020-06-02 21:33:35.314 traceZ-Wave Node 5: Repair is adding return route
sys:12020-06-02 21:33:35.307 traceZ-Wave Node 5: Repair is deleting routes
sys:12020-06-02 21:33:35.091 traceZ-Wave Node 5: Repair is requesting device associations
sys:12020-06-02 21:32:01.945 traceZ-Wave Node 5: Repair is requesting device associations
sys:12020-06-02 21:32:01.926 traceZ-Wave Node 5: Repair is updating neighbors
sys:12020-06-02 21:32:01.906 traceZ-Wave Node 5: Repair is updating neighbors
sys:12020-06-02 21:32:01.884 traceZ-Wave Node 5: Repair is updating neighbors
sys:12020-06-02 21:31:56.830 traceZ-Wave Node 5: Repair is updating neighbors
sys:12020-06-02 21:31:55.175 traceZ-Wave Node 5: Repair setting SUC route
sys:12020-06-02 21:31:55.023 traceZ-Wave Node 5: Repair pinging
sys:12020-06-02 21:31:55.020 traceZ-Wave Node 5: Repair starting
sys:12020-06-02 21:31:46.743 traceZ-Wave Node 4: Repair is done.
sys:12020-06-02 21:31:46.730 traceZ-Wave Node 4: Repair is requesting node neighbor info
sys:12020-06-02 21:31:46.726 traceZ-Wave Node 4: Repair is adding return route
sys:12020-06-02 21:31:46.716 traceZ-Wave Node 4: Repair is deleting routes
sys:12020-06-02 21:31:46.187 traceZ-Wave Node 4: Repair is requesting device associations
sys:12020-06-02 21:31:46.171 traceZ-Wave Node 4: Repair is updating neighbors
sys:12020-06-02 21:31:46.155 traceZ-Wave Node 4: Repair is updating neighbors
sys:12020-06-02 21:31:46.140 traceZ-Wave Node 4: Repair is updating neighbors
sys:12020-06-02 21:31:41.080 traceZ-Wave Node 4: Repair is updating neighbors
sys:12020-06-02 21:31:40.071 traceZ-Wave Node 4: Repair setting SUC route
sys:12020-06-02 21:31:39.997 traceZ-Wave Node 4: Repair pinging
sys:12020-06-02 21:31:39.987 traceZ-Wave Node 4: Repair starting
sys:12020-06-02 21:31:31.210 traceZ-Wave Node 3: Repair is done.
sys:12020-06-02 21:31:31.154 traceZ-Wave Node 3: Repair is requesting node neighbor info
sys:12020-06-02 21:31:31.149 traceZ-Wave Node 3: Repair is adding return route
sys:12020-06-02 21:31:31.144 traceZ-Wave Node 3: Repair is deleting routes
sys:12020-06-02 21:31:31.004 traceZ-Wave Node 3: Repair is requesting device associations
sys:12020-06-02 21:31:30.981 traceZ-Wave Node 3: Repair is updating neighbors
sys:12020-06-02 21:31:30.961 traceZ-Wave Node 3: Repair is updating neighbors
sys:12020-06-02 21:31:30.935 traceZ-Wave Node 3: Repair is updating neighbors
sys:12020-06-02 21:31:25.887 traceZ-Wave Node 3: Repair is updating neighbors
sys:12020-06-02 21:31:24.992 traceZ-Wave Node 3: Repair setting SUC route
sys:12020-06-02 21:31:24.960 traceZ-Wave Node 3: Repair pinging
sys:12020-06-02 21:31:24.950 traceZ-Wave Node 3: Repair starting
sys:12020-06-02 21:31:16.278 traceZ-Wave Node 2: Repair is done.
sys:12020-06-02 21:31:16.211 traceZ-Wave Node 2: Repair is requesting node neighbor info
sys:12020-06-02 21:31:16.207 traceZ-Wave Node 2: Repair is adding return route
sys:12020-06-02 21:31:16.195 traceZ-Wave Node 2: Repair is deleting routes
sys:12020-06-02 21:31:15.957 traceZ-Wave Node 2: Repair is requesting device associations
sys:12020-06-02 21:31:15.939 traceZ-Wave Node 2: Repair is updating neighbors
sys:12020-06-02 21:31:15.923 traceZ-Wave Node 2: Repair is updating neighbors
sys:12020-06-02 21:31:15.906 traceZ-Wave Node 2: Repair is updating neighbors
sys:12020-06-02 21:31:10.837 traceZ-Wave Node 2: Repair is updating neighbors
sys:12020-06-02 21:31:09.959 traceZ-Wave Node 2: Repair setting SUC route
sys:12020-06-02 21:31:09.851 traceZ-Wave Node 2: Repair pinging
sys:12020-06-02 21:31:09.842 traceZ-Wave Node 2: Repair starting
sys:12020-06-02 21:31:09.651 infoStarting Z-Wave Network Repair
OK, I am on site for the next 2 days - battery dead after 1 week, replaced and trying to make sure the new Aeotec 7 repeaters I brought are used by the lock - one is within 3 feet of the door, the other is within 1 feet of the HE. Repeaters were added successfully. Ran the zwave repair - successful. Lock has new battery and communicates with HE, I can get codes, add codes etc. Repeater is NOT flashing!
I also can't exclude the lock. I put HE into zwave exclusion, press the Schlage button, enter programming code (yellow LED comes on), press 0 - Yellow LED flashes but nothing in the LOG and the lock continues to respond to commands.
When I do the manual know lock / unlock, within like 4 repeats the lock will stop to communicate. Removing battery from the lock fixes the problem.
Any ideas for help please?
You are trying to excluding very close to the hub? Excluding and Including should be done with the lock very close to the controller. Different from other devices that you join and can usually exclude in-place.
Yes, moved the HE within few feet.
I may need to find a way to do the zwave map and verify which devices are using the repeaters. Is there any easy way i.e. some hidden web interface inside the Aeotech?
I know of nothing like that.
Which exclusion did you try? There's device exclusion, but there's also General Exclusion
I've had a General Exclusion work with some devices, where the Exclusion under the Z-Wave Details didn't. Not every device has responded this way, but some did.
I am using the devices-> device discovery -> zwave -> zwave exclusion
How can I use the cluster info under each of the repeaters to know which device is using it? For example I see this under the repeater close to the lock:
in: 0x5E, 0x85, 0x8E, 0x59, 0x55, 0x86, 0x72, 0x5A, 0x87, 0x73, 0x9F, 0x6C, 0x7A, out:
I don't see 0x0A (010) which is the lock, thus I don't think it is using it. Correct?
The in-clusters and out-clusters describe the properties of the device (z-wave command classes supported). Not which other devices it is connected to.
This document from SiLabs has a full list of command classes (warning PDF)
Yes, I did the physical thumb after inserting the batteries:
dev:112020-06-11 15:58:33.245 infoMain House Lock was unlocked by thumb turn [physical]
dev:112020-06-11 15:58:27.774 infoMain House Lock was locked by thumb turn [physical]
dev:112020-06-11 15:58:22.323 infoMain House Lock was unlocked by thumb turn [physical]
dev:112020-06-11 15:58:16.843 infoMain House Lock was locked by thumb turn [physical]
dev:112020-06-11 15:58:11.489 infoMain House Lock was unlocked by thumb turn [physical]
dev:112020-06-11 15:58:01.303 infoMain House Lock was locked by thumb turn [physical]
dev:112020-06-11 15:58:00.826 infoMain House Lock was unlocked by thumb turn [physical]
