Ah apologies - I didn't click into the read first post - just saw the initial paragraph indicating to share screen shots.
Here is more thorough reply
How is Hub being powered? Supplied power block or other (explain)
Hub is powered by the supplied power block plugged into a power strip plugged into the wall. It is near a Lutron Caseta hub (now disabled and not powered) and an IKEA Tradfri hub (not powered) and an Xfinity cable modem. The CAT6 cable is connected from the HE to a Netgear 5-port switch, which connects to the Xfinith modem- PoE power (with splitter) is known to cause major Z-Wave issues on the C-8 hub.
PoE is not being used
Screenshots showing entire Z-Wave details Page
top of page through node 0x04 pic
0x05 through 0x0e
0x0e through 0x22
0x22 through last item
- Screenshot of Z-Wave Topology Map (red/blue squares)
Regarding my comment about the Z-wave logs - it was in response to a comment in the help doc saying to keep the log open (from the side panel) - so I shared the logs that seem to have value (primary menu option called Logs from HE menu on left side) vs. the 'View logs' button in the Zwave Details page
