Zwave switches taking 20-30 seconds
Is it normal in HE to take 20-30+ seconds to turn on a zwave switch?
I am a month into HE and the delays are taking some getting used to.
not at all, that's too long. can you give a bit more info? which hub are you using? what version? what switch are you using?
Hi thanks for replying
HE7 latest released version.
Greenwave power monitoring sockets
It’s not consistent.
I need to dive into logs.
I am seeing delays under direct control from the HE UI on the device so will look ok at logs to determine where the delays are.
I am also finding that the Rules just not performing zwave actions that I need to debug also.
For example Goodnight routine some non zwave things get done other zwave actions are just not performed.
i'm not too familiar with these, do you have a model number? from a quick search, i was able to find some old devices that are just z-wave, not z-wave plus. not being plus would impact performance, and if it goes to sleep, it would also delay a response
He would probably want to install z-wave poller if they arent z-wave plus then. That would keep then awake and properly show status?
They are polled every five mins
Have been solid and fast for several years - got ~25 of them :slight_smile:
I am finding all zwave sluggish but need to gather logs and understand why.
Landing Temperature SRT
2021-01-31 12:55:53.885 seqNo: 5, routeChanged: true, transmissionTime: 0ms, repeaters: None, speed: Unknown, rssi: [0 dBm, 0 dBm, 0 dBm, 0 dBm, 0 dBm], Ack channel: 0, Transmit channel: 0
Guest TRV2021-01-31 12:55:53.388 seqNo: 8, routeChanged: false, transmissionTime: 0ms, repeaters: None, speed: Unknown, rssi: [0 dBm, 0 dBm, 0 dBm, 0 dBm, 0 dBm], Ack channel: 0, Transmit channel: 0
Guest TRV2021-01-31 12:55:53.387 seqNo: 7, routeChanged: false, transmissionTime: 0ms, repeaters: None, speed: Unknown, rssi: [0 dBm, 0 dBm, 0 dBm, 0 dBm, 0 dBm], Ack channel: 0, Transmit channel: 0
Guest TRV2021-01-31 12:55:53.386 seqNo: 6, routeChanged: true, transmissionTime: 0ms, repeaters: None, speed: Unknown, rssi: [0 dBm, 0 dBm, 0 dBm, 0 dBm, 0 dBm], Ack channel: 0, Transmit channel: 0
Guest TRV2021-01-31 12:55:53.384 seqNo: 4, routeChanged: false, transmissionTime: 199ms, repeaters: None, rssi: [-103 dBm, N/A, N/A, N/A, N/A], Ack channel: 1, Transmit channel: 1
Guest TRV2021-01-31 12:55:48.771 seqNo: 4, routeChanged: true, transmissionTime: 223ms, repeaters: None
Lounge Back TRV2021-01-31 12:55:48.471 seqNo: 2, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 40 kbs, rssi: [0 dBm, 0 dBm, 0 dBm, 0 dBm, 0 dBm], Ack channel: 0, Transmit channel: 0
Lounge Back TRV2021-01-31 12:55:43.560 seqNo: 2, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 40 kbs
Landing Temperature SRT2021-01-31 12:55:43.361 seqNo: 3, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 40 kbs, rssi: [-66 dBm, N/A, N/A, N/A, N/A], Ack channel: 1, Transmit channel: 1
Guest TRV2021-01-31 12:55:43.359 seqNo: 1, routeChanged: true, transmissionTime: 123ms, repeaters: None, rssi: [-103 dBm, N/A, N/A, N/A, N/A], Ack channel: 1, Transmit channel: 1
Guest TRV2021-01-31 12:55:42.257 seqNo: 1, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 40 kbs
Landing Temperature SRT2021-01-31 12:55:41.656 seqNo: 0, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 40 kbs, rssi: [-66 dBm, N/A, N/A, N/A, N/A], Ack channel: 1, Transmit channel: 1
Lounge Back TRV2021-01-31 12:55:40.654 seqNo: 255, routeChanged: false, transmissionTime: 2ms, repeaters: None, speed: 40 kbs, rssi: [-103 dBm, N/A, N/A, N/A, N/A], Ack channel: 1, Transmit channel: 1
Landing Temperature SRT2021-01-31 12:55:40.153 seqNo: 254, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 40 kbs, rssi: [-66 dBm, N/A, N/A, N/A, N/A], Ack channel: 1, Transmit channel: 1
Lounge Back TRV2021-01-31 12:55:39.150 seqNo: 253, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 40 kbs, rssi: [-103 dBm, N/A, N/A, N/A, N/A], Ack channel: 1, Transmit channel: 1
Landing Temperature SRT2021-01-31 12:55:38.649 seqNo: 252, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 40 kbs, rssi: [-66 dBm, N/A, N/A, N/A, N/A], Ack channel: 1, Transmit channel: 1
Lounge Back TRV2021-01-31 12:55:37.646 seqNo: 251, routeChanged: true, transmissionTime: 1ms, repeaters: None, speed: 40 kbs, rssi: [-103 dBm, N/A, N/A, N/A, N/A], Ack channel: 1, Transmit channel: 1
Landing Temperature SRT2021-01-31 12:55:37.446 seqNo: 250, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 40 kbs, rssi: [-66 dBm, N/A, N/A, N/A, N/A], Ack channel: 1, Transmit channel: 1
Lounge Back TRV2021-01-31 12:55:37.346 seqNo: 249, routeChanged: true, transmissionTime: 123ms, repeaters: None, rssi: [-103 dBm, N/A, N/A, N/A, N/A], Ack channel: 1, Transmit channel: 1
Lounge Back TRV2021-01-31 12:55:36.244 seqNo: 249, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 40 kbs
Landing Temperature SRT2021-01-31 12:55:35.643 seqNo: 248, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 40 kbs, rssi: [-66 dBm, N/A, N/A, N/A, N/A], Ack channel: 1, Transmit channel: 1
Landing Temperature SRT2021-01-31 12:55:34.139 seqNo: 247, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 40 kbs, rssi: [-66 dBm, N/A, N/A, N/A, N/A], Ack channel: 1, Transmit channel: 1
Landing Temperature SRT2021-01-31 12:55:32.636 seqNo: 246, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 40 kbs, rssi: [-66 dBm, N/A, N/A, N/A, N/A], Ack channel: 1, Transmit channel: 1
Landing Temperature SRT2021-01-31 12:55:31.132 seqNo: 245, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 40 kbs, rssi: [-66 dBm, N/A, N/A, N/A, N/A], Ack channel: 1, Transmit channel: 1
Landing Temperature SRT2021-01-31 12:55:29.628 seqNo: 244, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 40 kbs, rssi: [-66 dBm, N/A, N/A, N/A, N/A], Ack channel: 1, Transmit channel: 1
Landing Temperature SRT2021-01-31 12:55:28.122 seqNo: 243, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 40 kbs, rssi: [-66 dBm, N/A, N/A, N/A, N/A], Ack channel: 1, Transmit channel: 1
Landing Temperature SRT2021-01-31 12:55:26.619 seqNo: 242, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 40 kbs, rssi: [-66 dBm, N/A, N/A, N/A, N/A], Ack channel: 1, Transmit channel: 1
Landing Temperature SRT2021-01-31 12:55:25.116 seqNo: 241, routeChanged: true, transmissionTime: 1ms, repeaters: None, speed: 40 kbs, rssi: [-66 dBm, N/A, N/A, N/A, N/A], Ack channel: 1, Transmit channel: 1
Lounge Front TRV2021-01-31 12:55:17.095 seqNo: 238, routeChanged: true, transmissionTime: 2ms, repeaters: None, speed: 40 kbs, rssi: [-92 dBm, N/A, N/A, N/A, N/A], Ack channel: 1, Transmit channel: 1
Molly TRV2021-01-31 12:55:16.995 seqNo: 235, routeChanged: false, transmissionTime: 120ms, repeaters: None, rssi: [-104 dBm, N/A, N/A, N/A, N/A], Ack channel: 1, Transmit channel: 1
Molly TRV2021-01-31 12:55:15.792 seqNo: 235, routeChanged: false, transmissionTime: 1ms, repeaters: None
Master Bed TRV2021-01-31 12:55:15.592 seqNo: 219, routeChanged: false, transmissionTime: 2ms, repeaters: None, speed: 40 kbs, rssi: [-90 dBm, N/A, N/A, N/A, N/A], Ack channel: 1, Transmit channel: 1
Lounge Front TRV2021-01-31 12:55:15.591 seqNo: 108, routeChanged: true, transmissionTime: 119ms, repeaters: None, rssi: [-92 dBm, N/A, N/A, N/A, N/A], Ack channel: 1, Transmit channel: 1
Lounge Front TRV2021-01-31 12:55:14.487 seqNo: 108, routeChanged: true, transmissionTime: 21ms, repeaters: None, speed: 40 kbs
Master Bed TRV2021-01-31 12:55:14.287 seqNo: 107, routeChanged: true, transmissionTime: 21ms, repeaters: None
Master Bed TRV2021-01-31 12:55:10.975 seqNo: 107, routeChanged: true, transmissionTime: 14ms, repeaters: [25], speed: 40 kbs
Fridge PWR Meter2021-01-31 12:55:10.876 seqNo: 240, routeChanged: true, transmissionTime: 14ms, repeaters: None, speed: 40 kbs, rssi: [-77 dBm, N/A, N/A, N/A, N/A], Ack channel: 1, Transmit channel: 1
Fridge PWR Meter2021-01-31 12:55:10.874 seqNo: 240, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs
ZW0112021-01-31 12:55:10.674 seqNo: 239, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 40 kbs, rssi: [-63 dBm, N/A, N/A, N/A, N/A], Ack channel: 1, Transmit channel: 1
Guest Ensuite TRV2021-01-31 12:55:10.574 seqNo: 105, routeChanged: true, transmissionTime: 121ms, repeaters: None, rssi: [-101 dBm, N/A, N/A, N/A, N/A], Ack channel: 1, Transmit channel: 1
Guest Ensuite TRV2021-01-31 12:55:09.472 seqNo: 105, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: Unknown
ZW0322021-01-31 12:55:07.359 seqNo: 223, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 40 kbs, rssi: [-94 dBm, N/A, N/A, N/A, N/A], Ack channel: 1, Transmit channel: 1
Office Fan2021-01-31 12:55:06.959 seqNo: 207, routeChanged: false, transmissionTime: 3ms, repeaters: [24], speed: 100 kbs, rssi: [-75 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
Freezer 1 PWR Meter2021-01-31 12:55:06.957 seqNo: 202, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-61 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
ZW0382021-01-31 12:55:06.863 seqNo: 200, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-98 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
ZW0382021-01-31 12:55:06.861 seqNo: 166, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-98 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
Kitchen Scenter2021-01-31 12:55:06.857 seqNo: 165, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-100 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
TEST UNIT - Is ZWAVE DOWN2021-01-31 12:55:06.758 seqNo: 164, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 40 kbs, rssi: [-68 dBm, N/A, N/A, N/A, N/A], Ack channel: 1, Transmit channel: 1
Lounge Fireplace2021-01-31 12:55:06.756 seqNo: 163, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-94 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
ZW0072021-01-31 12:55:06.557 seqNo: 162, routeChanged: false, transmissionTime: 9ms, repeaters: None, speed: 40 kbs
Lounge Scenter2021-01-31 12:55:06.355 seqNo: 161, routeChanged: false, transmissionTime: 9ms, repeaters: [48], speed: 100 kbs, rssi: [-100 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
Lounge Scenter2021-01-31 12:55:06.255 seqNo: 161, routeChanged: false, transmissionTime: 4ms, repeaters: [48], speed: 100 kbs
Garage Tool Charger2021-01-31 12:55:06.155 seqNo: 160, routeChanged: false, transmissionTime: 4ms, repeaters: [22, 3c], speed: 100 kbs, rssi: [-75 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
ZW0032021-01-31 12:55:06.058 seqNo: 159, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-108 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
Master Bed Dawn Nightlight2021-01-31 12:55:06.056 seqNo: 158, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-76 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
Lounge - Broadband PWR Meter2021-01-31 12:55:06.054 seqNo: 157, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-75 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
Lounge Internet FTTD2021-01-31 12:55:05.961 seqNo: 156, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-94 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
Master Bed Mike Nightlight2021-01-31 12:55:05.956 seqNo: 155, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-92 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
Guest Left Socket2021-01-31 12:55:05.954 seqNo: 154, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-100 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
Office - Computer PWR Meter2021-01-31 12:55:05.154 seqNo: 153, routeChanged: false, transmissionTime: 1ms, repeaters: [25, 21], speed: 100 kbs
Fridge PWR Meter2021-01-31 12:55:04.953 seqNo: 152, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-75 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
Guest Right Socket2021-01-31 12:55:04.952 seqNo: 151, routeChanged: false, transmissionTime: 7ms, repeaters: None, speed: 100 kbs, rssi: [-97 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
Guest Right Socket2021-01-31 12:55:04.951 seqNo: 151, routeChanged: false, transmissionTime: 4ms, repeaters: None, speed: 100 kbs
Garage Lights2021-01-31 12:55:04.755 seqNo: 150, routeChanged: false, transmissionTime: 4ms, repeaters: [06, 33], speed: 100 kbs, rssi: [-63 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
Freezer 2 PWR Meter2021-01-31 12:55:04.751 seqNo: 150, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-79 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
ZW0112021-01-31 12:55:04.654 seqNo: 150, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 40 kbs, rssi: [-63 dBm, N/A, N/A, N/A, N/A], Ack channel: 1, Transmit channel: 1
Freezer 1 PWR Meter2021-01-31 12:55:04.653 seqNo: 147, routeChanged: false, transmissionTime: 8ms, repeaters: None, speed: 100 kbs, rssi: [-61 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
Freezer 1 PWR Meter2021-01-31 12:55:04.651 seqNo: 147, routeChanged: false, transmissionTime: 3ms, repeaters: None, speed: 100 kbs
Printer2021-01-31 12:55:04.550 seqNo: 146, routeChanged: false, transmissionTime: 3ms, repeaters: [4d], speed: 100 kbs, rssi: [-107 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
Lounge AV - PWR Meter2021-01-31 12:55:04.451 seqNo: 145, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-81 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
Kitchen Scenter2021-01-31 12:55:04.450 seqNo: 144, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-100 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
Lounge Fireplace2021-01-31 12:55:04.350 seqNo: 143, routeChanged: false, transmissionTime: 8ms, repeaters: None, speed: 100 kbs, rssi: [-94 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
Lounge Fireplace2021-01-31 12:55:04.349 seqNo: 143, routeChanged: false, transmissionTime: 9ms, repeaters: None, speed: 100 kbs
Lounge Scenter2021-01-31 12:55:04.249 seqNo: 142, routeChanged: false, transmissionTime: 9ms, repeaters: [48], speed: 100 kbs, rssi: [-100 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
Lounge Scenter2021-01-31 12:55:04.149 seqNo: 142, routeChanged: false, transmissionTime: 7ms, repeaters: [48], speed: 100 kbs
Garage Tool Charger2021-01-31 12:55:04.049 seqNo: 141, routeChanged: false, transmissionTime: 7ms, repeaters: [22, 3c], speed: 100 kbs, rssi: [-75 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
Master Bed Dawn Nightlight2021-01-31 12:55:03.948 seqNo: 140, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-75 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
Lounge - Broadband PWR Meter2021-01-31 12:55:03.647 seqNo: 139, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-75 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
Master Bed Mike Nightlight2021-01-31 12:55:03.551 seqNo: 138, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-91 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
Guest Left Socket2021-01-31 12:55:03.549 seqNo: 137, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-100 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
Fridge PWR Meter2021-01-31 12:55:03.547 seqNo: 136, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-76 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
Guest Right Socket2021-01-31 12:55:03.450 seqNo: 135, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-97 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
Freezer 2 PWR Meter2021-01-31 12:55:03.449 seqNo: 134, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-83 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
ZW0112021-01-31 12:55:03.448 seqNo: 134, routeChanged: false, transmissionTime: 8ms, repeaters: None, speed: 40 kbs, rssi: [-63 dBm, N/A, N/A, N/A, N/A], Ack channel: 1, Transmit channel: 1
ZW0112021-01-31 12:55:03.447 seqNo: 134, routeChanged: false, transmissionTime: 3ms, repeaters: None, speed: 40 kbs
Printer2021-01-31 12:55:03.248 seqNo: 132, routeChanged: false, transmissionTime: 3ms, repeaters: [4d], speed: 100 kbs, rssi: [-100 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
Lounge AV - PWR Meter2021-01-31 12:55:03.246 seqNo: 131, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-82 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
Kitchen Scenter2021-01-31 12:55:03.148 seqNo: 130, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-101 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
Lounge Fireplace2021-01-31 12:55:03.147 seqNo: 129, routeChanged: false, transmissionTime: 7ms, repeaters: None, speed: 100 kbs, rssi: [-94 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
Lounge Fireplace2021-01-31 12:55:03.146 seqNo: 129, routeChanged: false, transmissionTime: 9ms, repeaters: None, speed: 100 kbs
Lounge Scenter2021-01-31 12:55:02.947 seqNo: 128, routeChanged: false, transmissionTime: 9ms, repeaters: [48], speed: 100 kbs, rssi: [-100 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
Lounge Scenter2021-01-31 12:55:02.946 seqNo: 128, routeChanged: false, transmissionTime: 4ms, repeaters: [48], speed: 100 kbs
Garage Tool Charger2021-01-31 12:55:02.846 seqNo: 127, routeChanged: false, transmissionTime: 4ms, repeaters: [22, 3c], speed: 100 kbs, rssi: [-75 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
Master Bed Dawn Nightlight2021-01-31 12:55:02.751 seqNo: 126, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-75 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
Lounge - Broadband PWR Meter2021-01-31 12:55:02.748 seqNo: 125, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-75 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
Master Bed Mike Nightlight2021-01-31 12:55:02.650 seqNo: 124, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-92 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
Guest Left Socket2021-01-31 12:55:02.648 seqNo: 123, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-100 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
Guest Right Socket2021-01-31 12:55:02.646 seqNo: 122, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-97 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
Guest Right Socket2021-01-31 12:55:02.645 seqNo: 122, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs
Fridge PWR Meter2021-01-31 12:55:02.253 seqNo: 121, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-74 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
Freezer 2 PWR Meter2021-01-31 12:55:02.249 seqNo: 120, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-83 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
ZW0112021-01-31 12:55:02.244 seqNo: 119, routeChanged: false, transmissionTime: 8ms, repeaters: None, speed: 40 kbs, rssi: [-63 dBm, N/A, N/A, N/A, N/A], Ack channel: 1, Transmit channel: 1
ZW0112021-01-31 12:55:02.143 seqNo: 119, routeChanged: false, transmissionTime: 3ms, repeaters: None, speed: 40 kbs
Printer2021-01-31 12:55:02.042 seqNo: 118, routeChanged: false, transmissionTime: 3ms, repeaters: [4d], speed: 100 kbs, rssi: [-104 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
Lounge AV - PWR Meter2021-01-31 12:55:01.948 seqNo: 117, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-81 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
Kitchen Scenter2021-01-31 12:55:01.946 seqNo: 116, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-99 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
Lounge Fireplace2021-01-31 12:55:01.944 seqNo: 115, routeChanged: false, transmissionTime: 8ms, repeaters: None, speed: 100 kbs, rssi: [-94 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
Lounge Fireplace2021-01-31 12:55:01.942 seqNo: 115, routeChanged: false, transmissionTime: 3ms, repeaters: None, speed: 100 kbs
Lounge Scenter2021-01-31 12:55:01.754 seqNo: 114, routeChanged: false, transmissionTime: 3ms, repeaters: [48], speed: 100 kbs, rssi: [-100 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
Master Bed Dawn Nightlight2021-01-31 12:55:01.749 seqNo: 113, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-75 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
Master Bed Mike Nightlight2021-01-31 12:55:01.743 seqNo: 112, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-92 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
Fridge PWR Meter2021-01-31 12:55:01.645 seqNo: 111, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-75 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
ZW0112021-01-31 12:55:01.643 seqNo: 110, routeChanged: false, transmissionTime: 8ms, repeaters: None, speed: 40 kbs, rssi: [-62 dBm, N/A, N/A, N/A, N/A], Ack channel: 1, Transmit channel: 1
ZW0112021-01-31 12:55:01.641 seqNo: 110, routeChanged: false, transmissionTime: 3ms, repeaters: None, speed: 40 kbs
Printer2021-01-31 12:55:01.442 seqNo: 109, routeChanged: false, transmissionTime: 3ms, repeaters: [4d], speed: 100 kbs, rssi: [-101 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
TEST UNIT - Is ZWAVE DOWN2021-01-31 12:55:01.441 seqNo: 106, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 40 kbs, rssi: [-68 dBm, N/A, N/A, N/A, N/A], Ack channel: 1, Transmit channel: 1
TEST UNIT - Is ZWAVE DOWN2021-01-31 12:55:01.439 seqNo: 104, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 40 kbs, rssi: [-68 dBm, N/A, N/A, N/A, N/A], Ack channel: 1, Transmit channel: 1
Is this normal?
60 seconds of the ZWAVE logs.
Should I be working on reducing logging levels somehow? _ I do not believe I have anything set to debug on.
I am seeing response time to Device Switch On/Off to a Zwave switch (Greenwave) between 1 second and 30 seconds - ie ON wait for it to actually turn on then turn Off wait for it to actually turn off
Molly TRV2021-01-31 12:55:01.339 seqNo: 103, routeChanged: false, transmissionTime: 120ms, repeaters: None, rssi: [-104 dBm, N/A, N/A, N/A, N/A], Ack channel: 1, Transmit channel: 1
Molly TRV2021-01-31 12:55:00.237 seqNo: 103, routeChanged: false, transmissionTime: 1ms, repeaters: None
Odd my text was inserted near the end of the log not at the top
I have completed a zwave repair.
The Topology looks ok to me. - I do have ~20 battery devices.
This bit doesn't look promising.
What device drivers are you using for them?
thats normal for me too for battery operated contact devices for a door and other devices that hasnt been used in 12 hours or more
@a4refillpad I think you are referring to:-
Landing Temperature SRT2021-01-31 12:55:53.885 seqNo: 5, routeChanged: true, transmissionTime: 0ms, repeaters: None, speed: Unknown, rssi: [0 dBm, 0 dBm, 0 dBm, 0 dBm, 0 dBm], Ack channel: 0, Transmit channel: 0
Which currently showing
0x3A (058) PER: 67, RTT Avg: 35ms, LWR RSSI: 49dB
Neighbors: 1, Route Changes: 66 OKRepair in: 0x72, 0x86, 0x80, 0x84, 0x31, 0x43, 0x85, 0x70, out: 0x40, 0x25 [Landing Temperature SRT] None 01 -> 07 -> 3A 40kbps
The driver for this Thermostat is:-
SRT321 Thermostat by MeavyDev - Converted for Hubitat by Scruffy-SJB
Version 2.1  November 20 2020 - Added Z-Wave Plus Fingerprint
        2.2  December 31 2020 - Minor cosmetic tweaks, less debug statements into logs
                                                     - Minimum wakeup interval enforced
        2.3  January 7 2021 - Fixed bug with some versions of SRT321 not getting their configuration after I added the Z-Wave+ bits
Well it has all now settled down and for the last 2-3 days not had any zwave issues at all, everything is snappy, back to how it had been for years.
Could be several reasons for this.
The upgrade to 2.2.5 - I know they were addressing some issues where the ZWAVE sub system would crash/have issues with some drivers.
Could be that I reduced the loading on the system by reducing the check TRV cycle down to once every 5 mins instead of 2 mins.
Could be because I 'retired' 4 of the 30 Greenwaves.
It could be any of the above or something random, could be that the Mesh just stabilised, all could be a combination of all of the above.
Either it is now stable for almost for about three days.
Thanks for everyone's input - very much appreciated.
