I've been struggling with this thermostat for some time.
Sometimes my thermostat scheduler app manages to set it, sometimes it doesn't. Annoying to get up to a freezing house this morning and equally annoying to be in bed with the heating still whirring at night.
The SRT-321 is battery powered and only wakes every 1200 seconds but this shouldn't be a problem should it? Shouldn't Hubitat keep trying to set it until it works?
Am running a H7 on 2.3.9.193
You can see in this log for the device (its called "thermo4"):
dev:512024-11-21 07:18:58.525infoThermo4 Current SetPoint is 20.0 Current Temperature is 15.7 - Calling for Heat
dev:512024-11-21 07:15:00.097infoThermo4 Current SetPoint is 10.0 Current Temperature is 15.7 - Heat not needed
dev:512024-11-21 07:00:00.128infoThermo4 Current SetPoint is 10.0 Current Temperature is 15.7 - Heat not needed
dev:512024-11-21 06:59:09.845infoThermo4 Current SetPoint is 10.0 Current Temperature is 15.7 - Heat not needed
dev:512024-11-21 06:59:08.336infoThermo4 Current SetPoint is 10.0 Current Temperature is 15.7 - Heat not needed
dev:512024-11-21 06:59:08.331infoReport Received : Sensor MultiLevel Report
dev:512024-11-21 06:59:02.214infoThermo4 woke up - Current Temperature is 15.7 - Setpoint is 10.0 - Mode is auto - Operating State is idle - Battery is 54
dev:512024-11-21 06:52:32.200infoThermo4 Current SetPoint is 10.0 Current Temperature is 15.7 - Heat not needed
dev:512024-11-21 06:52:32.195infoReport Received : Sensor MultiLevel Report
dev:512024-11-21 06:45:00.092infoThermo4 Current SetPoint is 10.0 Current Temperature is 15.8 - Heat not needed
dev:512024-11-21 06:39:04.905infoThermo4 Current SetPoint is 10.0 Current Temperature is 15.8 - Heat not needed
dev:512024-11-21 06:39:03.448infoThermo4 Current SetPoint is 10.0 Current Temperature is 15.8 - Heat not needed
dev:512024-11-21 06:39:03.441infoReport Received : Sensor MultiLevel Report
dev:512024-11-21 06:38:57.145infoThermo4 woke up - Current Temperature is 15.9 - Setpoint is 10.0 - Mode is auto - Operating State is idle - Battery is 54
dev:512024-11-21 06:30:00.491infoThermo4 Current SetPoint is 10.0 Current Temperature is 15.9 - Heat not needed
dev:512024-11-21 06:30:00.329infoThermo4 Current SetPoint is 20.0 Current Temperature is 15.9 - Calling for Heat
dev:512024-11-21 06:19:00.646infoThermo4 Current SetPoint is 10.0 Current Temperature is 15.9 - Heat not needed
dev:512024-11-21 06:18:59.141infoThermo4 Current SetPoint is 10.0 Current Temperature is 15.9 - Heat not needed
At 0630 the Scheduler sets the temperature to 20 degress.... but you can see the thermostat keep reporting that its setpoint is 10 degrees.... until at 0718 I get up and set it manually by twiddling the dial!
I have no idea why its doing this. It doesn't happen always, just sometimes.
