Zwave Roller shutter devices
Hi,
is a z-wave roller shutter devices managed from hubitat (it's not in your compatible devices list)? Is it possible to set the roller shutter to a specific percentage (do you have an image of your interface for this specific device)?
Also, if I want to connect hubitat to google assistant in Italy, the voice command can be done in Italian?
If the device isn't on the supported devices list then you would have to find a community driver that supports it. The short answer to your question, no, you would not be able to set the percentage. Unless the device was able to pair and showed up as dimmer switch, which it could, then it would work. What is the specific device?
Sì signore. Benvenuto a Hubitat!!!
Hi,
this is https://www.widom.it/en/smart-roller-shutter/
I didn't try it with hubitat, I'm just asking before buying the hub.
Generally, Zwave devices will pair with the HE hub. Some devices require special drivers to include specialized settings and parameters but a generic driver should provide basic control. One of the included dimmer drivers would likely suffice for shutters. You might find a Device Handler on Smarththings that could easily be converted for Hubitat.
Yes. The Fibaro roller shutter controller works perfectly on HE
Yes, I frequently tell alexa “ set the conservatory windows to 30%” and she complies :slight_smile:
I’m not sure what you mean by image of the interface.
If you mean the driver then it’s built in.
I just use the ‘generic z-wave dimmer’ driver which works perfectly for me with the fibaro unit.
Andy
The Qubino Shutter Module and Qubino DC Shutter Module also control rollershades perfectly.
