Zwave is dead?
Hub C-8, Original power supply, original antennas, Locks are Yale 216 ZW2 (24 of them), using Generic Z-Wave Lock driver, 1 Zooz S2 800 light switch.
The Zwave seems to not be working anymore and the last "activity" of several units was 9/2 but I can't get it any updates on units, I soft reboots, soft reboots with database reset, disabled Zwave with reboot, Unit shutdown and unplugged for 20 minutes, Zwave Rebuild Network, Zwave Antenna Test, Zwave disabled Device and re-enabled.
One of the devices Log has data on 9/2 but nothing between 9/3-9/15 but 9/16 does show the Timed Out but back to nothing on 9/17-18.
Please help as I can't update my locks with new codes.
  • Charlie
What does the zwave table show? Do all of the devices have a check mark under status?
Yep..
This ... And if you could send me a private message with your hub id so I can check logs..
Sent, and thank you for looking into this! I wonder if the dashboard is stuck? All of the batteries have been replace with brand new just out of the box and good till 2029 batteries. Yet, 6 of the locks are showing "low batteries" but they all have new batteries.
Unlikely, if this is the built-in Dashboard app.
Yes, the default dashboard.
You have only 1 hardwired Z-wave device and 24 locks?
At least four hardwired, two upstairs switch and two downstair switch each having a front & back unit... Zooz Zen 76 S2 Switch.
Can you post your z-wave details page in its entirety?
Here are the screenshots, one device I noted was Unknown, I "think" I know which lock it is but I need to verify. Please continue to ask questions to solve this. TIA - Charlie
Ugh - all those 28 locks are paired with S0 security. That's a lot of traffic being routed via a small number of repeaters. I'm amazed this setup worked for as long as it seems to have.
While I don't have many suggestions to get this all these devices responding to the hub again, I have three questions that may lead to a resolution:
  1. Have you changed lock batteries recently?
  2. Are the line-powered devices controllable by the hub (meaning the switches)?
  3. What platform version is running on your hub? If you updated recently, can you revert back to the previous version using the Diagnostic Tool?
In any event, before trying to get the locks to work, I would recommend focusing on getting your line powered devices to work.
Finally, please also post a screenshot of the top of the z-wave settings page.
  1. Yes, I’ve put new batteries in most of the units.
  2. Yes, the line-powered devices (Zooz LR 800 switches) are connected and can be controlled by the Hub.
  3. Yes, the latest update. Can I revert to a previous version, I could but haven’t out of fear of finding myself in a worse situation. I have one of the Support guys looking into this and don’t want to do anything that might cause issue with his analysis.
  4. Attached is the screenshot from my phone of the zwave page, not sure how it will help but as requested. I’m not at home now but maybe the browser version is different from the phone app.
Thanks for the feedback and will post.
Please do revert to the last version on your hub where everything was working as expected. You can do so using the Diagnostic Tool. Select the option "Restore Previous Version".
@bcopeland What say you? I know that you are looking into this and I don't want to cause confusion on you doing A and me doing B... uncontrolled analysis can make things worst from my Aphla/Beta testing experience.
I would go back and turn off encryption on all those s0 devices (except locks) S0 is really chatty
It looked like they were all doorlocks. They may not allow nonsecure pairing.
I can't believe it ever worked good with that many locks and so few repeaters.
What type of home requires that many locks? That is the most puzzling part to me.
Rooming house/dormitory/multi-unit Airbnb …..
Escape Room(s)? :zany_face:
It worked fine up to 9/2 of this year.
It’s a commercial office space, low security with 18 cameras. It’s a small town and mostly tattoos, salons, small retailers and to go restaurant.
True commercial grade system would have cost over $20,000 at the time we bought this, yes over a $1k per lock for true commercial grade. For our needs, mostly 95% are Yale and work great for our needs. It’s been fine for years and no reason to stop seeing or updated. I put new batteries in most units, though tomorrow I might just do the rest.
I have a second C8 hub I could deploy if needing too but was planning on that one for my other building.
