TLDR: I accidentally reset a Z-Wave device and it automatically got exclusion from the hub. I expected the hub to still show the device and maybe to have a ghost device. C-8 Pro running Z-Wave JS.
The other day I realized that the LED strip light that is mounted behind my TV wasn't coming on in the evening as expected. The strip is plugged into a Neo Coolcam Power Plug. I went to my devices page to see what was going on, and there was no "TV LEDs" device. I checked the Z-Wave settings and there was no device and no ghosts. The device was automated via a Room Lighting app, but it wasn't listed there. So I did a Z-Wave include, which worked on the first try, and I added the device back to the Room Lighting app.
The past logs on the hub didn't show anything, but I export all my Hub logs to an external database and was able to dig into the older logs where I found this on August 30 at 16:07: "Z-Wave device TV LEDs (20) excluded and removed."
Checking Blue Iris, I was able to confirm exactly what I was doing at that time. I was connecting a new device to the Family Room TV which sits on a motion-mount with the Neo plug behind it. I had pivoted the TV away from the wall to access the back. The TV must have pushed against the plug and pressed the front-facing button on the power plug, and a 10-second press of that button will reset the device.
I thought that resetting a device wouldn't clear it from the mesh/radio. This seems like a good thing overall, because it avoids mesh issues with devices that have been reset, but the downside is that an accidental reset of a device completely wipes it from apps and automations. Is this something new with Z-Wave JS or did it always work this way?
