Zse50 light with contact sensor on rule machine
I have a zse50 alarm that I would like to turn it's light on (no alarm) when a window is left open and then turn it off when my wife closes the window.
Contact sensor is working good and alarm works good. This rule doesn't cause any activity.
Please post the triggers.
Even without the trigger, the rule should work manually.
if you run the rule manually and the window is open, does the ZSE50 light turn on?
If you run the rule manually, the ZSE50 light is on and the window is closed, does the ZSE50 light turn off?
You have to control the strobe on the ZSE50 as a dimmer. Run a Custom Action like below.
You have to do that too turn it off as well. When you select custom command instead of "strobe" select "off"
"Run actions" has no impact, regardless of the sensor status.
Here's my trigger
No luck, here's my changes.
It looks like if level is zero, strobe doesn’t work.
That was my problem. Thanks guys for the help!!
