I have 3 Zooz ZSE42 leak sensors around my house. The battery report on one of them is all over the place. Within a few seconds, it will jump from 40% to 1%. The other two don't seem to do that. Any ideas what might cause that?
Are they on the latest f/w available from Zooz? I don't use those sensors myself, so I don't know off-hand what f/w # that is, but that would be the first thing I'd check.
I can't seem to find the most recent published version from Zooz. But while checking, I found that one listed the firmware version, but the other didn't. As it turns out, I'm using different drivers on the one with issues. I'm going to change this one to the other driver (user supplied, back before Hubitat had a built-in driver for the device). If the issue is resolved, I'll leave it on the user driver.
The latest firmware for the ZSE42 is 1.40.
You can contact zooz support to get access to all of their firmware files.
I've updated all of my devices because they were doing strange things with batter reporting on older firmware versions.
