Good evening folks,
I am trying to include the Zooz ZSE40 to my system, unfortunately every time I select the Zooz ZSE40 from the device list, the Zooz ZSE40 comes back as a Zipato Bulb2.
I dug a little more and found a new driver, which I think I installed properly, but I don't know to update the driver in order to use it.
Any recommendation.
Dom
Where are you "selecting" this? If you're on the Add Device page, that wizard mostly just helps the hub figure out the protocol you're using and helps you figure out the inclusion or pairing process if they have it documented. It won't force the device to use a specific driver, so it's otherwise the same as just doing Z-Wave under Add a Device Manually.
What you can do--and what should work--any time afterwards is go to the device page and change the driver manually. This is the option under the Type dropdown. There is a built-in driver for the Zooz 4-in-1, but whatever user driver you added for this device should also show up there, too, if you prefer that (system drivers are listed alphabetically first, then user drivers--you'll see the separated). Then, select Save Device and hit Configure (in the commands at the top) if the driver has this command, and after that you may also want to wake up the device (press the Z-Wave button on the bottom of the device with a small object once) so you don't have to wait for its next automatic wakeup interval to pass for the settings to sync.
Note: These should be paired with no security if you have a C7 or they can cause problems with your mesh.
