Zooz ZEN77 dimmer with ZAC99 Momentary Switch
Hi!! Just wondering if anyone knows if its possible to use a Zac99 momentary switch with a Zooz Zen 77 dimmer in a 3-way instalation. As I uniderstand this Zac switch is ok for Zen 22 and Zen 72.
Thanks!
Tagging @agnes.zooz
You can't use a ZAC99 with the ZEN77. If you look at the diagrams, the ZEN77 is a simple replacement for the main switch with power and the other 3-way stays wired the same, with 3 wires attached to it. The ZAC99 is a single pole momentary switch so it wouldn't work here as it's not a 3-way switch and the ZEN77 can only communicate with regular on/off switches, it wouldn't work with a momentary switch. The ZEN72 model is what you're looking for.
