spokra
1
Good afternoon!
I have zooz zen77 and 6 sengled bulbs in my kitchen, and have two questions.
- is disabling Smart Bulb Mode - Load Control the only thing that needs to be done to switch?
- if i have all 6 bulbs screwed in all the lights flash, with 5 bulbs they work as expected. are 6 bulbs to high of a load for a zen77?
I know in another home I've used the same switch and bulb with 8 bulbs
Assuming those are smart bulbs, why would you want to disable smart bulb mode (SBM)?
6 led bulbs should be no problem for the 77 -- are they flashing with SBM disabled?
spokra
3
disabling paddle and zigbee in smart bulb mode - load control.
the previous bulbs would not dim without freaking out. I assumed they were not dimmable. cheap builder bulbs.
the zen 77 is on a three way circuit with 6 bulbs.
spokra
4
well i spoke to zooz the zen77 CANNOT be a 3way and smart bulb controller at the same time. fix is to replace with a zen72
system
Closed
5
